Torque Pro APP question
St. Louis
Spent a good 30 to 40 minutes with it today looking through all the PIDs to see if it was listed. Didn't see it. It may not be listed in the ECM but the TCM which either the app or adapter cannot see.
I have monitored this function before with the Tech-2, will pull it out next and see where that is located, ECM or TCM.
When I had my Tech2 out yesterday checking for codes I also went through all the screens looking at info. I'm pretty sure that TCC slip rpm was in the TCM.
I was watching it while idling and it would fluctuate really low numbers, like in the teens and 20s. I also compared it with the DIC info screen that the AutoSync adds with it and it showed the exact same readings as the Tech2 did.
The AutoSync DIC display also shows what gear you are in and if the torque converter is locked up or not by showing an * next to the gear number.
If memory serves, when mine is locked up the slip is like 10 or 12 rpms.
R
rjm20
Thanks for trying. Keep me posted.
St. Louis
Here's the DIC displays that I get with the AutoSync. These were pics from back in June that I also posted in another thread back then talking about engine Temps and when the fans kick on.
The AutoSync uses the mirror adjust D pad to switch between these screens. Up returns you to the default screen you have showing and down shows the backup camera on the Nav screen for like 5 seconds.
The right button shows this info....
Left button brings up this....
Pressing the left button again switches to this.....
So yes, the TCC Slip info is in there somewhere, we just have to figure out the PID info for it for Torque to read it.
St. Louis
Fired up the Tech-2 on a run last night and could only find the TCC slip speed in the TCM module, not the ECM.
Maybe Ken knows how to get the PIDs, he's been my "go to" guy for things like this. @kbuskill
The Torque app has a TCC Slip PID included with the GM predefined set but I don't get a response with it. I've changed the header from Auto to leaving it blank and I get a response, but it just stays at - 32 on the gauge. I think with the correct hex header it'll work on our trucks.
St. Louis
@rjm20
Got it working on my Torque Pro app!!
I was out adjusting my headlights and when I got done and went to pull it up the driveway I decided to open Torque and low and behold it was jiving with what my DIC said
In drive with foot on break. They both fluctuate and snapping a pic that corresponds to the screenshot is hard
Awesome! So what would one need to do in order to see it on the Torque Pro?
St. Louis
Well earlier today I reloaded the GM predefined set because I had the PID all messed up from messing with it. Even resetting it in the PID editor wouldn't put it back to original settings, soooo after doing that then re-adding the gauge it still wouldn't work and I went in and changed the header from Auto to just leaving blank like I posted earlier, but now it works.
Here's what I have for the PID info....
Thanks Tom! I set it up in mine and will go out to the car later to test it out.
R
rjm20
Everyone. Original poster here. IT WORKs. I was running the regular GM PIDs when it was not working. The error was in the "OBD Header to use" section. Mine was set to AUTO but when I cleared it out to BLANK, it worked.
I apologize for being MIA, I was not getting notifications that this thread was active. Thanks again for helping me with this.
Thrust
ICT
Thanks @gooffeyguy. I added this PID and it works great. I did notice my temp gauge on the torque app shows 160F when the SUV gauge shows 185ish F. Why the difference?
New phone, could not transfer data from old one. Cannot get Current Gear or TCC Slip Speed to work. Think I'm going to add AUTO since mine is blank and see if it works.
albac
