tore apart the ole Govbomb 10bolt today
AtomicHoe094
Atomichoe094
cleveland, OH
Govbomb to nice Trutrac Rebuild :)
Swapping out the drums to discs and had to pull the shafts, so i took off the cover, got the clips out etc etc. noticed the pin that holds the spider gear shaft (cross pin) was lose(came out by hand) and also has some wear on it. Can see where its been rubbed and scored the metal.
Anyone know the part number to this off hand? Should i go to GM or would the parts store have one?
Loktite?
Thanks brothers. I have a feeling this govbomb isnt going to last very long with that whipple. Well see what happens :) And damn i just spend 35bucks on lucas gear oil and a new gasket.. shit haha
clean454
rebuild it while u are in there might as well. u can do it ur self pretty cheap and its not that hard
A
AtomicHoe094
Atomichoe094
cleveland, OH
i could tear one apart, but ive never been inside one to rebuild. all those shims and shit wouldnt go so well. im going to blow it up first then build it up later.. and the axles laying on some jackstands, soo its not even bolted in lol
clean454
thats fine it doesn't have to be in the truck to be rebuilt but its prolly gunna break at a really bad time! LOL but if u have the extra cash then get it done!
when mine went out i had to use 4x4 to get home
A
AtomicHoe094
Atomichoe094
cleveland, OH
14048412 for a 8.5 locking differential.
SWEEET. thanks!~! i just ordered a 10bolt alum diff cover tonight yay haha
summit sent me a badass coupon;)
---------- Post added at 11:01 PM ---------- Previous post was at 11:01 PM ----------
ahha oh well. let it be. lol I mean ill be pissed ovcourse, but in the end, ill be like damn i should of listened to Clean 2 months ago :Handshake:
clean454
haha its all good when u get that cover make sure u sand down the inside where the bolt flange meets the case or it WILL leak
chrome and alm. leak all the time
just a FYI
96ProCompTahoe
IN
blow it to shit and post up some pictures! haha can you swap a 2wd 14 bolt into your hoe like the 4x4 swap? should hold the power a hell of a lot better.
what cover did you pick up? i have the mag-hytec extra quart cover on mine and love it. has a built in O-ring so no RTV and no leaks :D
SunlitComet
OBS Jedi-Do Good
unknown at this time.
here here
retorq
Kingman AZ
What happens if you o attempt to blow the rear and you lock it up, that's gonna lock up the drive shaft and tranny output shaft ... could be a hell of a lot more then fixing the rear end.
The 454SS rear is a 2wd 14 bolt 5x5 lug pattern axle ... not sure of the width though.
A
AtomicHoe094
Atomichoe094
cleveland, OH
pass over 600 bucks for this eaton i want, then ill put it in.
---------- Post added at 10:49 AM ---------- Previous post was at 09:27 AM ----------
53bucks for this damn bolt...
This is what broke in my brothers 03 silverado and then that blew up his rearend since the pin and shit came out..
96ProCompTahoe
IN
very big O-ring!
sounds like a junkyard run to pull that bolt out of another 10 bolt in my opinion:Handshake:
A
AtomicHoe094
Atomichoe094
cleveland, OH
im sure all of them would be like this huh? idk going to play it by ear and see what i can find. havent checked Egay yet
retorq
Kingman AZ
As far as I know the pins are all the same, the cross shafts can be different based on gear selection. :)
A
AtomicHoe094
Atomichoe094
cleveland, OH
well id be a lot happier if i killed the diff with a 6dollar bolt then a 53dollar one. lol Im gunna have to order that one today then.
Drewphil
