Tonyrodz's Tahoe Build Thread
Went to install my muffler today, but I bought 3" id/od adapters along with regular muffler clamps and it won't work. The muffler is 3", along with the stock exhaust, and unfortunately I bought regular muffler clamps instead of the v clamps. I'd rather have it welded, but no one around here will do it for less then $200. Excessive imo. Anyone have any suggestions on what size adapters to get? Or should I just get 2 V clamps?
I was able to adjust the rear swaybar to the most aggressive adjustment. 20220703_151631.jpg
Finally cut the muffler off the Tahoe. It was hot af--101 today. So of course I decided to work on the van too. The 3" v clamps were too big, should've got the 2.75" clamps. So gonna have the gf go tomorrow to get it welded up.
The seam split on the MBRP too.20220724_180057.jpg20220724_174411.jpg20220724_174401.jpg20220724_174345.jpg
97YukonNZ
The seam split on the MBRP too.View attachment 376304View attachment 376303View attachment 376302View attachment 376301
Inside still looked good tho.View attachment 376300
Oh for 101°f here!!!
Has been the coldest july on record here since 1977!!
You wont know yourself when you get the new mufler welded uo!
Will sound way better!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I was out there too bro! Funny thing is the sun is finally set behind the clouds and now it feels hotter?
Moderator
People's Republic of Colorado
Finally got the muffler welded. One place wanted $175 just to weld it--it was already mounted. Found a place to do it for $75.
Once I got home from work I took it for a ride, but it feels like it has a miss or something. Took a pic of fuel trims, as usual I don't know how to decipher the info. 20220726_171414.jpg20220726_171333.jpg
Anyone have any insight/idea what's going on here? Running and sounds not so great. I took the pics in park while giving it some gas. Tia.
Moderator
The short term trims are fine and those are your instant trims; anything within +/- 5 is great. Drive it a bit to see if they affect the long term trims -- those should come down if your STFTs are staying fairly solid as they sit now.
Might want to see if you can look at individual cylinder misfires, at idle and at 1,500 or 2k rpm, see if one cylinder is misbehaving.
I won't be able to look at it until this weekend. What could cause those fuel trims to be so off? Air/gasket leak of some kind? Bank 1 is the driver's side? Thanks for the info guys.
Ossipeelake
