Tire size recommendation.
Rsaxton22
I purchased a 2015 Tahoe Z71 about a year ago. It has a 2” leveling kit on the front.
The Tahoe came with 33x12.5xr18LT Terra Hunter X/T tires.
These tires rub very badly and are more aggressive that what I care for.
Any recommendations on tires (size) that won’t rub as bad, are less aggressive but still look good. And aren’t quite as loud.
Any help is greatly appreciated.
Well KO2s are hard to beat for looks. 12.5s are too wide with even a 4 or 6 inch lift. You can run a 275-70-18 and maybe get away with a 285-70-18. There are guys with your generation that run 34s, 275-65-20s with a level without rubbing. So the first option should be easy peasy.
R
Rsaxton22
Thank you very much. I'll probably go with 275-70-18 to be safe.
If you are looking for a quieter tire, you'll have to look for a less aggressive tread design. If most of your driving is on pave surfaces, you may want to consider a Michelin Defender tire. They are quiet, got performers in dry, wet, and snow, and they last for around 70,000 miles.
K2 Kaiju
The Depths
Yeah wow, those are really too wide. I am considering 275/70/18 next. I have Conti terrain contact HT in 265/70/18 and they are excellent road tires in every way, just boring looking like the defenders or alenzas. The terrain contact AT version is more aggressive, but still mostly a road tire. I will probably end up with those or one of the new grapplers (recon/exo). It will be a while as these are wearing very slowly, but I may find an excuse the ole lady will buy...
jscribn1
How about running a 17" rim on the Tahoe? Can that be done?
RB_Trucker
Redondo Beach
What’s up dude, here’s a sample tire size on my 3” lift it’s a 275-70/R18 Goodyear wrangler Territory MT on a 0 offset rim. The tires are the OEM Silverado ZR2 tire size and fit perfect. Quiet, smooth and work really good off-road. Aggressive but don’t over do it. I get a little rub at full steering lock going into a steep driveways on the bottom part of wheel well and stuff but that’s it. Rear is 0 rubbing.
Jeff_
Scottsdale, AZ & N. Idaho
That's the perfect stance and tire setup in my opinion. I need to upgrade from the bilstein 5100's to your 3" fox setup..
RB_Trucker
Redondo Beach
Definitely worth it, it is a Dirt King mid travel setup, I also have the 2.5 piggyback resi’s in the rear. Rides way better than stock did.
GroceryRunnr
I’ve got a Cognito motor sports kit…
3” Up front and added a 2” rear coil spacer.
Tires are Toyo RT 295/70/17
The only time I have some rubbing up front is at full lock driving either up or down a slope
Kerronic
Looking to do this kit. Have you flexed it out much? Do you get much rubbing? Just trying to decide how much more tire I can fit. Currently running 275-70-17
Fifty
Can you measure from the center of your wheel to the fender lip front and back?
I have 275/65/18 so measuring from the ground will not be apples to apples. But I’m curious as to ride heights.
Oh Kee Pah
MAINE
I would suggest a tire diameter around 33" with the +2" level kit installed. 34" diameter would be pushing it and possibly rub on rear of FRONT wheel well.
I think 285-295 is a nice width, especially given you're running the more aggressive tires.
The 33" tires also save you on weight compared to the current 12.50s. At least you have the 3.42 gearing with the z71 trim, that will help with the heavier tires.
RB_Trucker
Redondo Beach
Sorry for the late reply, I had my wife measure from hub center to bottom of fender and both my front and rear are at 26” hopefully that’s about right haha, I can recheck in a few weeks when I am back home again.
blackelky
I have 33s on my 2013 with a leveling kit not even close to rubbing at full lock
blackelky
I always suggest falken wildpeaks can't sing enough praises about those tires. Pirelli scorpion ats are good too but pricey.
GroceryRunnr
Hey! Not sure why im
Just getting the notification for your question now lol.
TBH I haven't done much wheeling with this rig. Have done a few fire roads which have been primarily flat. What I can say is that there is some slight rubbing at full lock when coming out/into a steep driveway. I have not modified the fenders whatsoever... so in a daily commute (in the city) I hardly ever experience any issues.
I really do want a set of 35s to fill her in more. I'm just too lazy to put in that extra fender work. I've had a modded Ram 2500 and most recently a Gen 2 Raptor, so any additional work in the Hoe isn't as thrilling
cmhorns
I have the 2018 tahoe z71 version with the front leveled, I run Toyo OC at3 295/55/20's (32.8x11.6) on xd820 20x9 0mm offset and I LOVE this setup! To answer questions on sizes and take the guesswork out of choosing the right setup, I recommend tiresize.com and wheel-size.com.
To add: I put 76,000 miles on the first set of these tires with tread leftover! I will NEVER choose another tire for this vehicle, period!
