Rick,Just joined the forum, recently purchased a clone Tech 2, opened an account with GM tech Line and can not down load supporting software into tech 2, I'm located in Easton PA. Any help would be appreciated.
You do not download anything into the Tech-2 from Techline. They just changed the way it interfaces with the Tech-2 and it is only used as a Pass-Thru device now if I understand correctly. Basically made my old laptop obsolete, they are wanting 64-bit machines I think now.Just joined the forum, recently purchased a clone Tech 2, opened an account with GM tech Line and can not down load supporting software into tech 2, I'm located in Easton PA. Any help would be appreciated.
Is Techline looking at the right port for the Tech-2? @Joseph GarciaMy tech 2 does not communicate with the desk top that I downloaded the tech line into.
I believe its looking at the right port. The tech line is set up using a keyspan Model USA-19HS-C USB serial adapter, I suspect that I have a defective DB9 serial port adapter that came with the Tech 2. I ordered a GM part # 3000111 replacement. Hopefully this will solve the issue. fingers crossed.Is Techline looking at the right port for the Tech-2? @Joseph Garcia
I downloaded the Tech line software onto my desktop windows 7 64 bits, i also had a friend download TIS 2000 onto an old XP desktop nether will communicate with the Tech 2. Thank you for reading my posts.You do not download anything into the Tech-2 from Techline. They just changed the way it interfaces with the Tech-2 and it is only used as a Pass-Thru device now if I understand correctly. Basically made my old laptop obsolete, they are wanting 64-bit machines I think now.
That being said, you can get the TIS2000 software to load onto an old laptop. It can provide programming for 2008 and older vehicles and use it to view captured data from the Tech-2, maybe even live if you take it out to the car.
Are you trying to program modules yet?
