on the obs you will need a gm software card and the tis2000 working, there is usually a small file (key) that gets put into the tis2000 software to unlock the softwareno I see 148.000 I have a Saab memory card installed in the tech 2.
My goal is to do the pass thru which I believe would allow me to program a second key fob, would also like to re-program the door lock.
@Rick R
Please describe how you are connecting your tech2 to your laptop. You may actually need a usb to serial adapter.
Sorry, way behind on this one.From post #9: "keyspan Model USA-19HS-C USB serial adapter"
As @Doubeleive noted, he'll probably have to see which port the serial adapter gets from his PC, then match that in the Tech 2.
As @Doubeleive noted, he'll probably have to see which port the serial adapter gets from his PC, then match that in the Tech 2 settings.
My vehicle is a 2008 Saab 9.3. ThanksYou shouldn't need the Tech 2 to program a second key fob; see the video I posted in an earlier message. Of course, you haven't yet told us what vehicle you have, or did I miss that?
On my Windows XP I connected directly to the serial port. I have reached out to my grandson how I am hoping will be able to help me, when the to school for computer science.@Rick R
