digitalfiend
Expert Overthinker
I did my free travel mod about a month or so ago. I then cycled the suspension without the springs in or shocks attached and installed small bump stops on top of the axle. The bump stops hit before anything else.
The problem is that I want to go lower and still have plenty of travel before bottoming out. Yesterday I pulled my springs out and disconnected my shocks then cycled the rear suspension all the way. The stock panhard bar will hit the crossmember...this occurs before the mounts that the bump stops ride on will hit the metal frame. My wife and daughter were out during the afternoon so once my son was down for his nap I took out my rotary grinder and cut a shape out of the cross member to clear the panhard bar and mount on the axle at full compression...
Hackery detail #1:
Hackery detail #2:
When the rear suspension is at full compression, the metal mount that the bump stops attach to hit first and there's plenty of clearance for the panhard bar and it's bracket:
Cleaned up the cuts and shot it with some black enamel paint (still wet):
I've only driven a couple miles with this done, so I need to put some more miles down first. To sum it up, this gives me the travel to run Tony's 6" drop springs and a 1" spacer (combined total of 5" drop in the rear) while still having great travel to only bottom out in extreme cases or when I'm carrying cargo.
Hackery detail #1:
Hackery detail #2:
