spacers and bearings
9C1C
Do wheel spacers damage your wheel bearings over time? Or is it a non-issue?
intheburbs
SE MI
They will cause them to fail sooner, yes. Simple physics - you're essentially using a bigger lever on them. How much sooner? That's the hard part.
Totally agree with all above. That being said, many folks do it without disasterous results. I commend you for recognizing the potential risks and asking the folks here for their opinions.
Other folks who do use spacers will chime in with their perspectives.
wjburken
Eastern Iowa
Anytime you move the centerline of the load out, you will increase the cantilevered load on the bearing. This can be done when people use spacers or put wheels on with less offset.
Dustin Jackson
Just like running wider wheels the spacers do the same things. It’s not a huge deal, might make them last 7 years instead of 10. Depends on how hard you are on it also
tom3
Son has a jacked up 06 Silverado with a good 1 1/2 in spacers on all fours with some big tires. No problems since he's had it. Front suspension parts sure keep him busy (and broke) though.
csan2879
