Seafoam
mmeachem
Yes i have searched sea-foam but wanted to know do i keep the throttle a 1500rpm while pouring it into the vacuum line and how much sea-foam do i put into the the tank and should I change the fuel filter after
Rivieraracing
You just wanna keep the truck running while putting it into the vacuum line, so i always tell my wife to keep the truck at around 1500-2000 and she does the best she can!! Also some advice would be to pour in the amount into a small container (I usually do at least half of the seafoam) so that way you know exactly how much to pour in. Just pour it in as fast as you can without killing the truck and then shut it off as soon as your done!
Rivieraracing
Not me, I make it drink it as fast as I can but without killing the motor! On your first seafoam take your time and you will know how fast you can get away with on your second time!! Just make sure to tell the person working the pedal to do everything in their power to keep the truck running, even if that means holding the pedal to the metal for a bit!! lol
mmeachem
mmeachem
So i do have to pour it fast thats what you do but HAVE to have someone hold the throttle in that range
Also do i have to change my plugs after
Jonah52
Senor ******
Cleveland
You don't need someone in the cab. In all my vehicles I have done it at idle and just not killed it, then shut it off and let it sit for 10 minutes or so and drive it harder then normal.
BigWheelinBubba
Troy, MI
Just a little heads up for seafoam newbies..
I've been using it for years on probably 15 different vehicles without issue. I SWEAR BY THE STUFF!
BUT..!
My 2001 Tahoe LT has 250k on the 5.3 and it was running sluggish. I came to the conclusion that it was carbon buildup and I needed to do something about it.
First I did the seafoam.. half through the booster hose and the other half in the tank with 8 gallons in it. The usual..It did what it was supposed to do.
Secondly I did some research on using E-85 as a cleaner and octane booster. I found that mixing 30% E85 to 70% premium (92oct) worked wonders! It really cleaned my engine and fuel system out nicely! Much better than I expected in fact! And my truck ran like it had never ran before!
So I continued to use the E85/Premium mixture every other fill up. The truck kept running strong and steady.
Well, to make a long story short I ended up getting a misfire while driving down the freeway. Figured a coilpack or something?
Get it to my buddies, put it on the scanner, found random multiple cylinder misfires.
After a little diagnosis we find that there is no compression on cyl.#1..
Cause: **A chunk of carbon buildup the size of a dime became lodged in the exhaust valve and hung it open long enough to cause bigger problems!
Outcome: Used engine with 120k on it
Lesson learned: Do NOT try to rapidly/aggressively de-carbon a high miles engine!
Trixxterr
Jax, Fla
Yup, this is the way I have always done it. I just put it in as fast as it will go w/o killing the engine, and as I'm almost finished just dump the last lil bit in and it kills it. Wait, and then drive the piss out of it for a few miles.. smoking the entire neighborhood on my way out. LOL.
I've done this, on all my cars. Both Tahoes, Z28, and Durango. All w over 150k on them. No ill effects. But that's just my experience..
musicman
I have only used it on small engines (atvs and such) but it has worked wonders. Gonna do it this spring on the Tahoe.
Crowder99Yukon
My Yukon has close to 150,000 miles. I take it this would be a good idea to try lol. But do I run a higher risk of carbon getting stuck in one of the valves?
Sent from my HTC One S using Tapatalk 2
06GMC5.3L
BUT..!
Damn, that sucks. I did it a while back at like 80K. Planned on doing it again soon now that I am over 100K.
Sent from my iPhone using Tapatalk.
Gzes
the drifting 2dr
Wichita tx
Seafoamed the civic yesterday. Funny seeing the nebors being like wtf?
BigWheelinBubba
Troy, MI
I was running an E85 mixture also which probably contributed a lot to the carbon coming loose. I wouldn't worry too much if you're just going to do a seafoam treatment. :happy107:
Brace
