Roof Rack Removed
mjenk430
Unionville, VA
I removed the roof rack on my new Tahoe today, but unsure if I like it, what do you guys think?
Not sure the best way to seal up the holes, just put the stock bolts back in for now. I wasn't sure if the holes were sealed, so I poured a little water into one of them and it didn't fill up so it must not be sealed. I guess I now have a little water in my headliner :)
If I decide to keep the roof rack off, I was thinking about switching to set screws with some plumber's thread sealant on the threads (Think that will keep water out??) and then using plastidip to cover the screw and nut? Anyone have any better ideas??
mjenk430
mjenk430
Unionville, VA
Doorside molding.
From my Walkie Talkie
Huh, you mean like the piece I plan on taking off the side of the truck? Hadn't thought of that. It would look like another ripple in the roof. Do you know of anyone that has done it that way? Any pictures?
Do you think I can get those pieces already painted Summit Whiite (without the chrome strip like the ones I will be taking off)?
Goodinblack
I Like Tacos
Dirty South
I have seen them in white....yes... that is what I was suggesting.
The proper way is to weld....
Someone here did that too.
mjenk430
mjenk430
Unionville, VA
I definitely won't be cutting, welding, bondo'ing and repainting the roof. It gave me enough heartburn taking a grinder to the frame for the free travel mod. :)
I'll do some searching around and see if I can find a pick with the door molding and see if I can find it to purchase. Thanks for the idea.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
took mine off and it looked good but up close you can see it. Espically more that the truck is lowered. I also worried about water getting and and leaking into headliner
Donnie Yukonie
Yates Caretaker
Looks good but as stated maybe a small drop would make it look better
Goodinblack
I Like Tacos
Dirty South
I have a link to the moldings....
I will post it when I am at a PC.
Goodinblack
I Like Tacos
Dirty South
Those plugs can get expensive. They are $25.00 for two of them.
Sent from my GT-N8013 using Tapatalk 2
99tahoe5point7
