Rocket Man's 2008 Bagged CC Silverado Build AKA "THE MACHINE"
when you want to program the switch just go to tdsweb, purchase the $40 subscription, this will activate your vin for 2 years of unlimited programming.
then before you start be sure everything is plugged in and ready to go
get your laptop out and the tech2 and be sure all the cables are good-n-tight and position everything so you don't have to move it.
for good measure plug in a 12v dc supply to the tech2 and plug that into a wall socket so it doesn't have to depend on the car battery for power.
plug in your laptop power supply to the wall so it doesn't depend on the battery either.
then open up tdsweb on your laptop, run the java software through your web browser from tdsweb.
it will install about 4 or 5 small java programs/updates, then you can click ok and proceed
at the main menu it will give you some choices such as "tech2 passthru" this is what you will want to select.
follow the instructions to the T
it will tell you to turn on your tech2, be sure the ignition key is set to run (engine off)
then you will be instructed to read the bcm calibrations (from the tech2) and then return to the tds web app on the laptop
from there you will be able to navigate the tds web app to update the calibrations you want, there may be numerous choices but you should be able to determine what is what via the app, it will have check boxes and multiple choices and descriptions, most of them are defined by rpo codes but should have some type of definition, once you have all the check boxes you want selected it will let you proceed.
then it will tell you programming can take anywhere from 10 minutes to more than a hour (this is why you want everything plugged into wall power)
then just let it do it's thing, as it goes along it will beep and give a dotted line as it progresses.
when it's finished it will say it's competed and you can just leave it and cycle the key and test your mirror switch.
if all goes well your done.
Thanks Wes.
do you have a usb to serial adapter and the cable to communicate with the tech2 from your laptop?
or does your laptop have a serial port?
No serial port. So I need a male rs232 to usb, right? The ribbon cable that came with the Tech2 goes to the upper left side of the Tech2 which connects to the female rs232 that came with it, then I need the male rs232 to USB adapter ?
There’s a place on the laptop to connect that ribbon cable to but tis2000 says it can’t communicate with the Tech2.
then you can use the little serial to rj45 adapter that should have came with your tech2
after you have the usb serial adapter plugged into the laptop you will need to go into the system control panel and determine which serial comm port it assigned to the adapter usually com 4 or com 7, then when you are in tdsweb you tell it which comm port to use to communicate with the tech2
It took awhile but I finally got the Tech2 to communicate with the laptop. I haven’t purchased the subscription yet it that’s next. I still have the truck torn apart troubleshooting other stuff plus I need the door wiring harnesses. Getting closer to being ready though.
I received the three other door panels today and all three have broken mounting tabs and screw races in the grab handles. This means the metal plate that the bolts go through to mount them to the truck have no strength since half the screws won’t hold them to the door panels, and the handles themselves will just pull off soon. I have contacted the eBay sellers. 2 came from Flarda and one from South Carolina. They can either refund me or send replacement handles, they aren’t sold separate unless you find someone who is parting out door panels lol. This officially sucks. On another note, I got both front door wiring harnesses from an 08 Tahoe with DL3 mirrors and all 4 latch cables from a local yard.
"Do not like" but also "like".
lol- "Flarda"
Sam Harris
Texas
Weak ****** sauce
I'm sure those ebay sellers will do something for you--unless they want negative feedback--which they don't.
brice715
