Rims and tires
Devious_Tahoe96
Mr. Budwieser
West Texas
Ok so im gunna place an order for some cragar soft 8's. 15x10. Now i know alot of people have said that you can fit a 31" tire without cranking the t-bars. When you mean 31" tire is it An actual 31x10.50R15?? Or 285/70/15?? Lol i know its a stupid qustion but a want to make sure the order is right
h0tr0d
Brenham, Tx.
That should fit no problem without cranking the bars. That size is roughly equivalent to the 265/70/16 tires I had when I got my truck and they didn't rub at all with stock backspacing. You should be fine with the 4.5" BS with that tire size...I was rubbing pretty bad at first, but mine are 32.7"
Check my picture album out and you can see what that size will roughly look like. The picture is called "how I got her" or something like that...the one with the stock rims.
Now hurry up and order your rims and tires then post pics so we can see 'em ;)
Here is what I use to calculate tire sizes...
http://www.4wheelparts.com/aux_incl/tire_calculator.htm
Devious_Tahoe96
Devious_Tahoe96
Mr. Budwieser
West Texas
Thanks hotrod :Handshake: im gunna go to a tire warehouse today and check out some M/T's maybe A/T's not too sure yet. Any reconmendations on what kinda tires i should get??
h0tr0d
Brenham, Tx.
I'm happy with my Nitto Terra Grapplers so far, but I haven't had them very long. I wanted something that looked rugged, but was honest with myself when I chose the tires. I do about 85% driving on the street and honestly see mud and deep sand out in the country more often than most people around here that run boggers. They serve my purposes well and don't annoy the heck out of me driving on pavement like a really aggressive M/T would do.
---------- Post added at 07:47 PM ---------- Previous post was at 07:44 PM ----------
Oh crap! I just saw that you're going to get a 10" wide rim dude. You better check the manufacturers website of the tires you want, most of those tires you're talking about getting shouldn't be put on a rim wider than 9" dude. Sorry for not spotting that earlier.
Devious_Tahoe96
Devious_Tahoe96
Mr. Budwieser
West Texas
Yeah most of the tires that are 275 and up aren't going to work. Im gunna have to get tires starting in the 30's lol some 4 wheel center down here in el paso has a 96' silverado sitting on 44" boggers with a 15" rim lol
Only reason why i want 31's is cuz my friend has a 96' bronco with 33's and i need tires that'll be able to go through his ruts.
h0tr0d
Brenham, Tx.
I'm just saying that you might be a little better off with an 8" wide rim to fit a larger variety of tires. Is there any particular reason you're going to the 15" instead of the 16? Are you looking to air way down and need the sidewall flex?
The 10" wide is going to stick like way out and you might run into more issues with rubbing. Most of the guys here are running an 8" rim....the 8" wide rim will bring your tires flush with the back openings. The front's will stick out about 2-3 inches past your front openings if you're not running flares. It looks good IMO.
If you were to say get a 16x8 soft 8...it's still going to look tough as hell, stick the fronts out a bit, flush the backs...AND...it will allow you to run stock size tires if you want. Check out my album pics....I can take some different profile shots if you want to see how much the 8" wide cragars will stick out.
Just my two cents. Also, have you ever been out to Big Bend...I'm planning a trip for me and my friends there next year and would like to talk to some peeps with experience in the area.
Devious_Tahoe96
Devious_Tahoe96
Mr. Budwieser
West Texas
Reason why I got the 15x10.5 was so that i could run more agressive tires. I like the way the tires will stand outside of the wheel wall, but i don't want to have rubbing issues.You think i might have to do any trimming of the bumper or side fender?? What if I put the 15's in the rear and run 16's in front, or vice versa???
And Big Bend sounds awesome, but no i've never been out there before, only thing is that im enlisting in the Navy so idk if i'll still be here in el paso or somewhere else. We can stay posted though, I've heard its a 4x4 jungle out there lol
TigerEyz3
Slow and Steady
TN
As far as mixing 15s and 16s...
One, I don't think you can fit the 15s on your truck due to the caliper/drum requirements (I could be wrong due to the year though).
Two, I wouldn't recommend mixing the wheels as your overall tire diameter will be slightly different in most cases... bad for 4x4 engagement.
Three, I'd recommend getting the same size wheels front/rear for rotation/tire longevity reasons as well.
wicked2000
El paso TX
Only reason why i want 31's is cuz my friend has a 96' bronco with 33's and i need tires that'll be able to go through his ruts.[/QUOTE]
You should be able to beat your friend with any tire. I have a friend that has a bronco with a 351 and I wooped his ass at red sands when I had it stock. My hoe did better stock than the way it is right now.:emotions122:
Devious_Tahoe96
Devious_Tahoe96
Mr. Budwieser
West Texas
I get MAD tire hop out on the dunes!!! Thats why i need new tires lol i have 35% tread left lol now mudding at the sac, the Tahoe is a beast
Devious_Tahoe96
Devious_Tahoe96
Mr. Budwieser
West Texas
I took off my 16" stock rim and swapped it with the 15" cragar and it was sitting nice and flush. I'd show you pic's but my wife has my laptop.
johnsonwillie199
