This is my AFTER sheet. I'm fine with the front, I reckon to correct the rear toe, the rear bushings ought to be replaced. What say you?
@George B With it being a Multi-link suspension wouldn't it technically become out of alignment when the bushings start to break down?The rear is a solid axle... since the boxes are grey I image they aren't live numbers.
When you planning on putting in that rear axle?Thanks Chris! @iamdub
If the LR toe is off, I reckon my only option is to replace the control arms. We did the panhard bar earlier this year but not the rear upper and lower control arms yet. I was kinda waiting to do them when we swapped in the 14-bolt axle. Tire doesn't look toed in. If it stops raining I'll take some pictures.
