Radiator Fan Issue
c6Vette05
Phoenix, AZ
I have searched the forums for the past few days, and google as well, only thing kind of close is this thread but it isn't quite the same: https://www.tahoeyukonforum.com/threads/electric-radiator-fans-running-more-than-usual.84960/
I have a 2011 Tahoe 5.3 LT 2wd with towing package. Now that it is hot here in Phoenix, when I turn on the car and the AC is on (AC and recirc), the left fan runs at really high speed while the right fan doesn't. The battery gauge reads just past 14 V. When I am driving, the right fan kicks on, I see the battery gauge drop down a bit, below 14 more like 13 or so. I pulled over and checked and the right fan was on, when it turned off the battery gauge went back to normal. I did not have a multi meter with me at the time.
A, is this normal?
B, is it a fan motor issue or an ECU issue?
C, not sure if it is related or not, but the AC does get hotter (up to 48 degrees) and humid for less than a minute (I timed it) occasionally and then goes back to blowing 38 degree air (measured with digital thermometer). These measurements were on a 104F degree day. Yesterday at 109F driving home for 40 minutes, it did this cycle only 3 times.
Thanks for any help!
as far as I know it is normal for one fan to kick on higher than the other depending on the given situation I believe the ac system is cooled more on the right side, there is a known issue for some fans to cause the harness to get hot and melt the harness but I believe it was for very specific vehicles and it was a recall (or TSB) which involved just replacing the harness connector, but you could always check with your local dealer just to be sure if yours is in that range of vehicles or not.
Big Mama
Virginia
Agreed on the fan and you can go to nhtsb website to see recalls and complaints
mikeyss
Longmont, Colorado.
I was a GM tech and can tell you, this is Not normal. They both run at the same speed at all times. If they are commanded on low, both are on low. If commanded on hi, they both run on hi. However, if you use a tech2, you can command one fan to go on hi and the other on low, it's sort of a relay test. Replace your fans, especially where you live, you'll overheat at some point.
gpracer1
Phoenix
What mikeyss said, and don’t worry about the volt meter. I’m also in Phoenix and on full blast on a hot day the voltage can go down to 12.5 or so which looks really low on the gauge. I’m guessing the ECU is trying to not boil the AGM battery at those high ambient temps.
However if both fans run, you could replace the relays first and cheaper diagnosis.
maybe because mine are a 7/9 blade it just sounds like one is running faster than the other, thought it might be normal otherwise. when I upgraded mine I put brand new motors on so must just be my imagination, lol
C
c6Vette05
Phoenix, AZ
Thanks everyone and especially mikeyss. I will get new relays tomorrow (just found out the parts numbers and will call the dealerships to see if they have it). The current relays look find but for $25 or so it might be worth trying. If that doesn't fix it then I will get a new fan motor. Luckily I have an older Pathfinder I took out of storage while I am getting the Tahoe fixed up so it is not being driven around.
BG1988
A, is this normal?
Needs more Engine Fan Fluid!
my does it with remote COLD start.. Perfectly normal if you are that worried keep an eye on the temp gauge should be a 1-2mm passed the middle.
it had been about 100F outside the passed few days.. mine stays at 15Volts (14.8 but rounds up to 15volts)
that is includes the dual A/C system ON
but it is a High Voltage Direct Current to 12+VDC step down. 185amps
i can check tomorrow it's going to be like 97F
C
c6Vette05
Phoenix, AZ
Doh, engine fan fluid, how could I have missed that!
On another note, the problem has been solved. Replaced all 3 radiator fan relays and both fans now turn on/off in sync. Outside inspection of the old relays shows no signs of damage, wear or melting.
Thank you mikeyss!
mikeyss
Longmont, Colorado.
I'm glad you fixed it.
I meant to reply to this the other day....mine sound the same on both sides. Only difference mine may have than yours is that I have the later style K5L dual 700W 5 blade no rim fans. They are louder than my 05 fans that have a rim around the blades.
C
c6Vette05
Phoenix, AZ
Guess it is not solved yet. Issue came back, although the right fan does work more often now. At start up only the left fan works, after driving the right fan turns on.
I will buy a new fan harness and try that first (if it is something that is just plug and play) and then a fan motor.
C
c6Vette05
Phoenix, AZ
Anyone know if the fan motor can be changed without taking the radiator fan shroud assembly out? Trying to determine if the fan motor can be accessed from the aft of the radiator shroud. Thanks!
nope, the shroud is pretty easy to take out anyway, take off the intake housing and push the radiator hose back by hand it comes right out
edit: I would say "maybe" you could do it but it's going to be a real ***** compared to just taking the shroud out, there is 3 pressure clips and I think 3 screws (not sure it's been a minute since I did mine), then you have to clearance to get the fan and motor out, then put it back in and put it back together.
Thanks, I saw your post here https://www.tahoeyukonforum.com/threads/electric-fan-mods.100757/
Was hoping it would be that easy but I guess not. There is a youtube video showing how to take out the fan shroud assembly, not too painful. Was only concerned about the transmission cooler lines. Was planning on doing a transmission fluid change anyway.
Thanks Wes
it may be possible depending on which fans you have, on mine the original motors screwed in from the backside, on the k5l you have take the blade off from the front (pressure clip) then the motors are screwed in from the front behind the fan blade, (see photo)
if you find you have to disconnect the transmission lines it's pretty easy as well, the little black plastic ring slides off exposing the "C" clip if you use a small poker tool you can push it off enough to grab with a set of needle nose pliers, after the clip is off they just pop out, any fluid loss is very minimal not more than a few tablespoons. install is the reverse, push the tube in, put c clip on, slide black plastic ring back into place.
C
c6Vette05
Phoenix, AZ
Mine are the 5 bladed ones like in your picture. I will try that first since it would be easy, will wait until Monday night though.
Want to call a few dealer part departments see if they have the radiator fan harness that has been known to go bad. Do you know the part number for the harness by any chance?
I like being thorough and don't want to just replace the motor and still have the issue if it is in the harness.
C
c6Vette05
Phoenix, AZ
Thanks! That is exactly like the 1aauto video I found describes it. At first I was worried about air in the lines but I see that is not an issue.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=2ahUKEwj96aGSjZDjAhXVo54KHdk0CjIQFjAAegQIAhAC&url=https://gm.oemdtc.com/Recall/16145/RCSB-16V868-8298.pdf&usg=AOvVaw1NFe_KIPJCSoWQKeb2Uxa2
should be 13580874
V8Soulja423
