InspectahDEck
- Joined
- Oct 15, 2013
- Posts
- 44
- Reaction score
- 22
On my 05 yukon I noticed the PCV valve hose was brittle and broken off, so I ordered a new hose, as well as a new PCV valve (GM 12567915). When attempting to remove the PCV valve itself, it appears to be welded on, or at least I cannot remove it from the valve cover. In the process of using vice grips, the PCV valve stem is a bit disfigured now.
Upon further research, it seems the PCV valve is not removable, and instead part of the valve cover, is this accurate?
The new hose will slide on the PCV valve, it got squished into an oval shape instead of a circle, but I can squeeze it back into a circle. Any issues with this?
