Part numbers.....STR C4557, but there was two choices according to extended length and had to remove one and measure to get correct.Do you have the Part numbers?
I did lol?By the way, @Tonyrodz, great call about the Cooper AT's + tires. Load range E and 80 psi max pressure. I run them at 42 psi. Handled flawlessly and performed great. I am doing 80 mph thru the mountain curves that say to go 50-60 mph. I know the Hellwig bars are a big help but those tires stuck like glue and the wear is flawless. Thanks for the heads up on those tires.
My memory is terrible lol. Glad I could help. Cooper makes really good/nice tires. Had them on my 03 when I 1st got it and loved them.@Tonyrodz, I asked if ANYONE had comments about the Cooper tires I was thinking about and you chimed in with a positive reaction. I jumped and am happy I did. You gave me superb info.
Well, I just bought all new AC Delco park brake cable assemblies. At the end of my recent trip, last two days, I noticed a rhythmic moan/chirp noise coming from the rear as I would accel from a stop. Did not affect safety of the brakes and I kept driving home and paid close attention to any changes. The noise was intermittent at best. Went to see my friend at his shop and he sent me a pic of what we found, so I could forward here. The left rear park brake cable had not completely released and caused a dust buildup in the drum hat. The drum hat was not damaged and neither was the rotor. All cleaned out and found that the cable was not releasing properly in the cable housing. Pushed the cable back and have not used parking brake at all since then and noise is gone. I like to set my park brake and so I ordered all new cables and they have arrived from RA. Shipping and parts and TYF 5% discount brought it all in at around $105. Gonna do the replacement on Aug. 9. Next big job on my rig will be complete blend door actuators replacement and new heater parts and a/c parts. Gonna make sure to replace the rear a/c-heater hose assembly that runs under the rig. The way my rig performed on my 5500 mile trip recently, I still love it and see no problem updating these components as I have done so far. I know that my long trip went as well as it did because of my TLC I have done so far on this rig.
Threaded cable. My new one looks like this on one end: https://www.rockauto.com/en/moreinfo.php?pk=372405&cc=1431156&pt=1696&jsn=942
Mine is just the cableOk, that's the one I got, too, from RA. No nut, and no new dual cable connector, though. The bag had been opened, so I'm not sure if either should have been there. My old ones are in good enough shape.
”NEW” Rig!Now let's talk about the mechanical and maintenance items. This is a complete list of what has been done so far:
1. ALL fluids changed. Brake fluid, trans fluid and filter, coolant, power steering, front axle, rear axle, transfer case, oil and filter....etc.
2. New brake rotors, front and rear and new pads front and rear. New parking brake shoes and all adjusting assembly.
3. All 4 oxygen sensors.
4. Trans Corvette servo.
5. All 4 KYB shocks for Auto Ride Suspension.
6. All cooling system hoses and new tees at the firewall and new reservoir and cap.
7. Both belts and tensioners and idler.
8. New MAF and MAP sensor.
9. New Cam and Crank sensors.
10. New plugs, wires, air filter and clean throttle bore.
11. New rear upper and lower control arms.
12. New high mounted third brake light.
13. New transmission cooling lines.
14. New thermostat.
So do I!!Nice work. I’d like to lend you my Tahoe for a while.![]()
That is exactly why I am staying busy at my home shop. Just yesterday I spent 1.5 hours looking at a 2007 Honda Pilot for a P0301 and P0303 misfire, oil leak and rub noise at front when turning left and right. The noise was just the new aggressive tread on the tires she just bought. The oil leak was obvious from a just done, 8 months ago, oil pan seal replacement and I found a few very loose attaching bolts. I tightened all bolts and cleaned all off on the pan and all around it. Was dripping on exhaust and she could smell. Was adding about 1/2 quart of oil every month. The smell was the biggest concern. The misfire codes had been ongoing and her "mechanically inclined" fiance had already replaced all 6 plugs and all 6 ignition coils. It had started out with just a P0301 but after he did the parts replacement, the P0303 came up. I pulled both coils and plugs for #1 and #3 cylinders and they were not tight enough to compress the compression washer on the plugs. I fixed that and cleared the codes and told him to pull the other 4 plugs and inspect and reinstall and tighten enough to compress the washers. It would normally take 1-3 days to have codes come back after checked at a parts store and clear codes. i was saving this single mother money by having him do the 4 other plugs. I also explained to him/her about what I had found on you tube about the pcv and egr causing misfire codes. I showed him the pcv location and where the egr was and told him to watch the videos to address them. I did check for a vacuum leak and found none. The plugs I pulled looked pristine and so I did not do the compression test because it idled smooth and acceled smooth but was intermittently throwing the code P0301 and then the new code of P0303 after his work on plugs and coils. I had the 1.5 hours in it at $60 an hour and I gave her a break and charged her $60. She tried to pay me $80 but I would not take it. She will tell others.I've noticed around here lately there is a huge demand for auto repair these days. A lot of the work is not the high tech stuff but more routine repair that people just don't want to pay the $100 an hour dealer shops to do. Good independent shops are super busy these days.
