Noisy early morning transmission ?
The 6 speed transmission in my 07 Yukon XL Denali is not any more noisy at first in the mornings, than at any other time in the day. In fact, I don't notice any noise from it at all. Perhaps, it is because I have a loud exhaust system, and I'm just not hearing the noise, but I doubt it.
Other folks will chime in with their opinions and experiences.
sealandsky
Minneapolis, MN
if you let it run a few minutes before putting it in gear does it help? or does it make noise even when in park?
wjburken
Eastern Iowa
Never noticed any difference in any of the 6 speeds in our vehicles and we have some cold mornings here in Iowa, much like you can have.
Hi, Are all these 6 speed transmissions so noisy at first in the mornings ? Seems kinda strange to me, my 1990 Chevy Silverado 700R4 is quieter than the 2015 Tahoe !
James, what kind of noise(s)? I can't recall ever noticing mine making any kind sounds. Maybe they are drowned out by the transfer case and front differential!
Miami-Dade
Moderator Supporting Member
Never noticed any noise in my 6 speed transmission in the cold weather when I was in NYC in November and December.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
You can hear the planetary from inside? I can barely hear my wife anymore!
Yes, ever so faintly. If I have any other noise in the vehicle including the window down I cant hear it. I actually have to “listen” for it. The truck is still new to me so I hear and notice everything! Drives me nuts!
Kelsda
New Jersey
My wife’s 2018 Tahoe with a 6 speed is whining I thought it was in the front end dropped of at the dealer tonight I will let you know what we find out maybe as soon as tomorrow still under warranty
Kelsda
New Jersey
So similar to your vehicle as it warmed up noise went away
Dealer just called right front wheel bearing replaced good but truck only has 33,000 on it I had an 07 avalanche same thing cheap bearings
Floep
Buy her the FUR coat, the whine will stop, don't be so cheap
cireallin
I just went through this recently and the dealership ended up doing a full service on the transmission after multiple visits. Eventually it was replaced under extended warranty.
Escalade2007
