NO DRILL Rear Cargo Area Tie Down Solutions?
BlaineBug
Clown World
Has anyone come up with any no-drill solutions for adding rear cargo area tie downs? There are the 2 chrome flip-up tie downs mounted at the very rear of the cargo area at the tailgate but there is nothing behind the second row which would be beneficial for securing cargo.
B
BlaineBug
Clown World
maybe use the lower latch points for child seats on the back of the second row
That's not a horrible idea. I already utilize the mounts you speak of with a rubber bungee to secure a toolbox I keep stored between the second row captains chairs. However these are located in the very center of the second row captain's chairs (an unknown number of inches from the wall) and also slightly below the cargo area, versus at the tip top of the cargo area and at the edge of the cargo area flooring which is what would be preferred.
Also if utilizing these tie downs for child seats you would not be able to fold the second row seats without unstrapping your load.
B
BlaineBug
Clown World
What to you clip to those anchors with? The anchor looks like it doesn't stick out very far, which may limit what is used. It DOES seem to be an excellent idea, though. Thanks.
S hooks on the end of a rubber bungee. If your ratchet strap hook won't fit you can use a smaller diameter S hook to bridge the gap I suppose.
B
BlaineBug
Clown World
Something like this may perform better. If you are really cranking down on your ratchet straps, the threaded function of these buckles will keep them from spreading apart unlike your standard bungee cord S hook. And will also be safer in the event of a crash! Should be sold at any hardware store.
The only thing I don't like is that the seats can't be folded forward for access if you have a load strapped down as the load will be strapped down to the seats themselves rather than the body or frame of the vehicle. Still a NEGATIVE!
CrashTestDummy
Pearland, Texas
Those were actually what I was thinking about using. Need to know if they'll clear the loop. They look like they will, but I've come across some situations where they don't work.
Yeah, I know the seats are then stuck in the down and set position, but we rarely fold the seats up, since that's where the 4-legged kids ride.
B
BlaineBug
Clown World
They sell them in various sizes and thicknesses. Or get a heavy duty spring loaded hook clip.
Stbentoak
I'm going to resurrect this again as I see the solution proposed, but I'm wondering if this isn't too much pull on the seat. Also, how would you get those forward-facing rings to face backwards toward the load? I'm thinking about possibly folding both rear seats straight up and trying to anchor something to the seat frame floor for transport. Want to cross strap something down tightly but don't really like the idea of pulling on the seat back so hard....
B
BlaineBug
Clown World
I never ended up doing anything, I just keep my toolbox in-between the driver side front seat and the second row seat.
B
BlaineBug
Clown World
Nice idea, but I have my 3rd row installed - although virtually permanently stowed unless for cleaning. What is the 3rd row anchor point? Are you speaking of the 3rd row bottom seat belt bolts?
Sparksalot
Bastrop County, Texas
The anchor points for the seat itself. I removed it just a couple of weeks after I bought the truck. The powered seat must weigh a hundred pounds.
Stbentoak
I think I'm going to strap to the cross piece where the 2nd row bucket latches to and keep the seats flipped up for the duration of the haul. That is a solid anchor point and doesn't rely on seat integrity.
B
BlaineBug
Clown World
Those anchors in the floor are a good choice.
koomie98
