Lowering Springs?
leileisdad
Denver, CO
Hi guys,
I have been seeing a lot of posts regarding spindles and kits...
Im not too familier with what the "3/4" and all those numbers mean...
I have 26's on my tahoe, I just want to get rid of some of the fender gap... I see the prices for the spindles and kits, and they are over my budget...
I am thinking about getting some lowering springs, I see some that lower the front 1 to 2 inches in the front and 3 to 4 inches in the rear..
what do yo think about the lowering springs?
Thanks!
Modded
That Guy
Been there done that. Get drop spindles in the front worth 2" of drop. Then rear 4" drop springs. This will give you a 2/4 drop. If you try to drop down 2" in the front off the Belltech struts it may not ride so good.
If $ is an issue then save up for a bit. If you do it right you will only have to do it once, not 3 times like me!!
A 3/5 drop on 26s like what I have requires some pretty extensive modifications including the free travel mod and a stronger panhard bar. Also need sway bar end links, trailing arm relocators, new shocks all around, drop spindles, drop coils and a long time for cutting, malleting and heating. I doubt you want to do all that.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
i use beltech 2 front and rear 3 drop. Really it can be a 4 drop as you dont have to install the 1 inch spacer in the rear, but it makes it look way to low/
blueflamed03
Oklahoma
The 3/4 isnt 3/4", its 3" up front, 4" in rear. Like a 2/3 is 2" front, 3" rear. I did keys up front and 3" coils in rear of mine, but have 20's.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
how many miles on it?
autoride or non autoride?
I shot yah a pm on a few set ups.
L
leileisdad
Denver, CO
Your drop is sweet! And your right, I don't want to go that low...just wanna get rid of fender gap..
Sounds like a 2 inch drop up front with spindles and 4 inch lowering springs in the rear should have it sit nice then. Oh and mine is 4wheel drive, does that matter at all?
---------- Post added at 01:27 AM ---------- Previous post was at 01:24 AM ----------
Your tahoe sits really nice... what size wheel do you have?
And I'm assuming you mean belltech 2 drop spindles in front , and lowering springs in the rear?
---------- Post added at 01:29 AM ---------- Previous post was at 01:27 AM ----------
Awesome info guys...
But it sounds like no one does lowering springs up front...
So why is that?
NASTY GM
Nor Cal
What he said :cheers:
sumo
rhode island
I have 22 on mine. using spindles will keep the ride the same. Everything in the front is unaltered. the spindles lower the front by moving the hole for axle higher, but the angle of the axles dont change at all. springs will make the ride quality change, and could lead to quicker Tire wear if not properly aligned
Modded
That Guy
So why is that?
4WD will be pretty close to the same as a 2WD install just that you have a CV shaft.
I used the police recommended Pedders drop springs on all4 corners in the past and the rear rode like a dream (best ride I have had with drop springs on a Tahoe) but was only worth a 3" drop. The front rode good for like 1000 miles then rode like absolute junk. The Pedders people told me I could get their front performance struts and it would ride good again but I opted not to do that because I wanted to go lower anyway.
I have used
L
leileisdad
Denver, CO
Thanks so much guys! I wish all of you were close by...I'm in denver... its really hard to find customizing specialists here... I'm gonna put my wheels on by the weekend, then I will repost with some final questions..
Thanks again!
DB1337
