Lowered escalade with auto ride
chistoso
Arizona
Can anyone tell me if theres a way to bypass or cheat the autoride to keep them from lifting the ******* Lac or should I just go with a set of Belltech SP's I have sitting here..
Max
Mile High
Denver
Turn down the adjuster links in the rear so there is less distance between the caps or trim the link shorter.
Max
Mile High
Denver
Not much I'd just pop the lower side off and twist it up into the cap, then stuff the other end as far into the lower cap as possible and it should stop filling.
Max
Mile High
Denver
No problem dude. I didn't know you already dropped it when you getting the 4s?
chistoso
chistoso
Arizona
The links can't be shortened but there is another hole on the bracket where the lower part of the liks atttaches. can I just move the link over?
Max
Mile High
Denver
You may have to grind down the links, otherwise I have a set of shorter belltech links I can snail mail you today.
chistoso
chistoso
Arizona
Let me try something if not I'll let you know.. How much you want for them?
Max
Mile High
Denver
PM me your address, they're just little aluminum sensor links I can't use them for anything :Handshake:
Modded
That Guy
Yeah I have extra sensor link sitting around too, pretty sure they can work as the 00-2010 Tahoes all have the same rear suspension.
vjr021
Clearwater, FL
Is there a write up on adjusting the bars??? I'd like to do mine as well...
Also is there a write up on removing the autoride completely?
Narco
Atlanta
i thought you had to get a whole new set of rear shocks to drop the autoride
chistoso
chistoso
Arizona
I think I got it to work.. I simply took off the links, popped off one of the ends and trimmed off about an inch and put it back together. It sits just perfect and the auto ride kicks in only if I get a few bodies in it..
Sam Hamm
when u buy a kit it tells you to bend then at like a 70 degree angle but when i did they broke so i just measured the length they were suppose to be at popped the end off cut it at that length and glued it back on. if i can find the paper i will tell you the correct length they are suppose to be.
Sam Hamm
love ur truck bro. ive been wanting to ditch the 6s for 4s for a while now.
briannorris
