A switch to synthetic? I believe you should have been using synthetic from the get go. It is required by GM and is clearly stated in the owners manual. I only use 5w-30 mobile one or royal purple. Both of these fully synthetic oils have detergents to prevent sludge. In these LS based engines there are a lot more critical parts that have small tolerances that conventional oil cannot protect. If you have a 99 or newer Tahoe/Suburban you should ALWAYS use a fully synthetic 5W-30 and this will greatly reduce your chances of engine noise or failure.How's your oil pressure? I had a plugged oil filter just a couple of months after my oil change. So be on the safe side you could try replacing it.
This was after a switch to synthetic. A trip up to Kamloops pulling a trailer cleaned more out.
It starts ticking when cruising on the highway. It comes and goes. Any tricks? In wanting to do a 6.0 swap but I was hoping to get that done in spring.
I got the truck used last year. I have no idea what oil was used before.A switch to synthetic? I believe you should have been using synthetic from the get go. It is required by GM and is clearly stated in the owners manual. I only use 5w-30 mobile one or royal purple. Both of these fully synthetic oils have detergents to prevent sludge. In these LS based engines there are a lot more critical parts that have small tolerances that conventional oil cannot protect. If you have a 99 or newer Tahoe/Suburban you should ALWAYS use a fully synthetic 5W-30 and this will greatly reduce your chances of engine noise or failure.
My 2002 Yukon manual does not mention anything about synthetic motor oil. The only synthetic requirement is for the rear diff. When did they start "requiring " synth motor oil?
Got the oil changed. I added some lifter stuff I bought at advanced and ran it about an hour or so before changing the oil. The oil that came out was gross. Absolutely disgusting. I changed the filter and added 6 quarts of Valvoline 5w-20 that's dexos approved blah blah blah. Anyway when I started it to check my oil pressure it was at 40 psi at idle. I never remember it being about 20 at idle since I've owned it. At about 2k RPMs (cruising rpm) it was at 60 psi. I've NEVER saw my oil pressure above 40,EVER! I'd say this kind of jump in psi is a good thing and will keep the lifters quiet. If not I'll order some lifter stuff from Lucas and give that a go.
How are you looking a month later?
The pressure slowly dropped off as suggested it would above. I did as suggested and changed only the filter. Pressure instantly jumped back up and then slowly dropped again but at a slower rate. Took about 500 miles first time and 1500 miles the second time and changed the filter again and that was about 1000 miles ago and it hasn’t dropped yet. I’m changing the oil this weekend. So I’ll just keep rolling and keeping an eye out for a lightly used 6.0
I heard that. No ticking/tapping noise still though?
Just at initial start up for maybe 30 secs to a min. Had the gm shop here say it could be a lifter but they would venture to say its piston slap. Who knows. All I know is it goes away. If it was constant I would be pulling heads for sure
No Ticking at all so thats a good thing.
oil pressure shouldnt drop off like that after being warmed up. I would spend $10 and change thge filter again and so every 1000 miles or so for about 5000 miles then another oil change.
Do you recall what you used?
The dealer told me the oil pressure can vary. I notice it varies with engine speed and load. When the engine is cold, the idle RPM will be higher which will result in higher oil pressure. Once the engine warms up, the RPM will drop, and the oil pressure with it.
Since using Valvoline synthetic, and pulling a trailer up the Coquihalla (a long tough climb involving 10-12% grades), much of my startup noise is gone.
Well I think I found the source of the noise. I checked over everything today and decided to double check the exhaust manifolds. Turns out I’m missing the bolt closest to firewall on drivers side
