Lifted/Leveled 2021 - Postem Up
LekGMC
Am I crazy to want to put 295/70/18’s on a 22 suburban RST that’ll have a 1.5” strut spacer? Seeing the guy with stock suspension who runs 285/70/17’s made think lifting 1-1.5 more inches, shouldn’t I be able to clear a 34” tire?
@DWSmoot, seems like you have great experience with tire sizes on different level lifts. Do you think it’s possible with some trimming? Have you had to trim on any of your setups?
Also, I would hope to run a zero offset method wheel with it.
Thanks everyone for any guidance you could give!
DWSmoot
DWSmoot
Charleston, SC
I don’t have the experience on 18” wheels, but I am running a 11.7 x34.6” tire on a RV 2” lift with minor trimming. My offset is +24 and my wheels are 22s.You will have more chance of rub with a 0 offset. I believe there are some guys running 0 offset on 20” wheels with 34”tires? Maybe somebody can respond if so…
LekGMC
I thought I’d post mine up since I’ve asked a million questions on here. See if I could help someone else with questions. I ended up just doing the lower strut spacer (said it was 1.5”) with 18x9 method 316’s and 285/70/18 Nitto Ridge Grapplers. Zero rubbing but I’m very very close to the liners…I think I pushed the limits and barely got away with it.
sanman28
Outstanding. Looks great with a subtle beefy look. 70 series tires on 17's or 18's are the sweet spot for off road looking SUV's. When you say close to liners, is it the height or the width that is getting close?
Diggerz44
