- Joined
- Aug 2, 2018
- Posts
- 10,540
- Reaction score
- 15,298
SUPER TRIP!
Love this movie. My Christmas tradition.
Reminds me of the old late 70’s thru early 80’s Cadillac cornering lights. My mom had a ‘78 Saville that had those.Added cornering lights to the Burb to assist with dark roads/driveways at night.
I really like them.
I will get some more photos in the daylight.
Also added these...
View attachment 472886View attachment 472887
More cool mods. Nice.Added cornering lights to the Burb to assist with dark roads/driveways at night.
I really like them.
Also added these...
I dig it! I've been considering the same, because the level of tint on my front windows means that you can't see sh** at night when turning and I often lower the window to see what I'm turning into.Added cornering lights to the Burb to assist with dark roads/driveways at night.
Did you use a "delay off" relay in the circuit?
That's the sort of thing I'm prone to doing! Hella's version runs $65-$80, depending on the supplier. The adjustability is nice, but not $50 more nice.Kinda, I made my own with a Relay+Capacitor+Diode.
Could you use a brake line flaring tool to add a real flare to the metal line? I've done this on older cars where formed rubber hoses aren't available. I make metal bends, flare them, and splice them into straight sections of hose. It's typically low pressure, too, but gasoline, which you REALLY don't want leaking.I will say that the 5/8" hose is slightly "loose" when slipped over the factory metal lines after cutting the crimps and removing the original hoses, but I just slipped the hose up over the "barb" that was left after cutting the crimp off and put a hose clamp on both sides of the "barb" and I haven't had any issues or leaks in the past month or so of running it like this. The cooling system is a relatively low pressure system at 15-20 psi so I don't forsee any issues and I don't have to worry about the plastic quick connects breaking and dumping all the coolant like the ones under the hood did.
What kind of clamps did you use?Forgot to post this when we did it a while back.
I replaced the rear sections of rubber hose going to the rear heater core as well as the plastic quick connect fittings at rear heater core.
I don't trust the plastic quick connects so I found some metal ones to replace them. I used a Fordham rotary tool to cut the crimps off of the factory lines where the metal meets the rubber and then removed the old rubber lines and replaced them with new hoses with a 90° bend at one end.
No picks of the work but it's just boring maintenance stuff.
Here are the parts I used to upgrade everything...
Gates 28471 90 Degree Molded Heater Hose 5/8"
Amazon.com: Gates 28471 90 Degree Molded Heater Hose : Automotive
Buy Gates 28471 90 Degree Molded Heater Hose: Heater - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesa.co
Dorman 800-409HP
The factory plastic quick connects have a 90° bend in them and are crimped onto the rubber hose. I couldn't find a metal quick connect with a 90° bend. So my solution was to get the straight quick connects and get a hose with the 90° bend. This ended up working out great.
I will also note that I don't think the plastic quick connects in the rear probably see as much of the extreme conditions that the ones under the hood do, since they aren't right over the top of the exhaust manifold like under the hood. The old plastic ones I removed from the rear didn't seem nearly as brittle as the ones up front, even with 350k miles on them.
You probably could but there isn't a ton of room to work as the metal lines run on top of the frame rail and only stick out a little bit from the frame.Could you use a brake line flaring tool to add a real flare to the metal line? I've done this on older cars where formed rubber hoses aren't available. I make metal bends, flare them, and splice them into straight sections of hose. It's typically low pressure, too, but gasoline, which you REALLY don't want leaking.
Just some good stainless worm gear clamps.What kind of clamps did you use?
You beat me by 160 pounds! LOLI forgot to mention.
I put the Burb on the Cat scales at the truck stop yesterday to see what the ol' girl weighs fully laden with a full tank, family, luggage, a hitch carrier full of tools and two 5 gallon cans of gasoline.
7480lbs total
3440 front axle
4040 rear axle
In case anyone cares... I'm looking at you James, @swathdiver ... lol
Thanks brother, so far it has been awesome.You beat me by 160 pounds! LOL
Safe travels my friend!
