K9lovers's truck with belltech 2/3-4 Kit
NORCAL SS
SUV SUSPENSION GURU
He used this kit here from me.
http://tbssowners.com/store/index.php?act=viewProd&productId=106
In front the struts are set at 2 inches and in rear the adjustable 3-4 inch springs are set at 3 inches.
NOTE---- You can cut the rear 1 inch spacers down so if you wanted a 3.25/3.5/3.75 inch drop you can do that no problem.
STOCK
LOWERED 2/3
KMeloney
Tony -- You need to correct your fist sentence to say FRONT...
crazycrew
Vacherie, LA
Looks good. That's the exact kit I'm gonna get from Tony. What are his wheel/tire specs??
NICE :waytogo: Huge difference....
noob
New Orleans
Would that kit work on a 2010 escalade with out magnetic ride control?
k9lovr
Virginia
They are 275 55 20's. Thanks for the compliments, tony really helped me when trying to decide on the set up. Ride real nice as well
fire730
Louisiana
Need to do this to the wife's 07 Tahoe. Maybe after I recover financially from bringing the kids to Disneyworld in March. LOL
Any problems with getting the alignment back into specs or pinion angle problems with the rear drop? Would I need or do they make a trailing arm kit for the 07+?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
with 4 inch kit i usually do rear djm kit which is 165 shipped. pinon is fine though at 3 inches.
alignment is fine but if you do spindles/struts then you need alignment cams
k9lovr
Virginia
I had it aligned 4 days after I lowered it and the shop said they had no issues.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
no cams needed and here is the kit on my customers 2011 escalade
attachment.php
noob
New Orleans
That car has magnetic ride control, mine doesnt, i have a base model, does that make a difference?
itsspeeds
Rock Falls, IL
Gettin antsy seeing how good that looks!!! Would that drop work with a 22" rim. If so what kind of offset?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
22x9.5 with 35mm offset 305 40 22 no problem
itsspeeds
Rock Falls, IL
Sweet!! Looks like I know what to do now. Just gotta get cash to do it.
Norcal can you send me a link of that kit?
worleytrev93
