redwing4900
- Joined
- Dec 6, 2018
- Posts
- 68
- Reaction score
- 13
Hello everybody I’m sorry for the provocative title for this one but its truly my question.
I purchased my 1998 Yukon in the fall and because of the cold weather only just finished a full motor rebuild complete with machine shop rebore (.040 over) and reconditioned vortec heads. the PO mentioned that he had the transmission rebuilt then the head gasket blew and left it sitting in his driveway for three years until I bought it. Today I finished the final assembly and put all accessories and brackets on but was extremely disappointed when the starter would only click when I turned the key. It’s the exact noise the starter made when I first bought this thing with a seized motor.
I removed the spark plugs thinking the lower compression would at least get the motor to spin, but no.
So should I measure the torque value of how much force is needed to turn the motor? Would that help to paint the picture better? I know that idea sounds whacky but since I measured all crank specs when assembling and believe that I’m within them—now I’m wondering what else i can do.
Another issue that happened was when I poured anti freeze into the thermostat housing before installing the new one and checked for leaks none...at first. While installing the distributor and plug wires I hear some antifreeze gushing from the middle of the engine where it meets with the transmission. This is my first engine build in case you couldn’t already tell.
There was also antifreeze where the EGR pipes come out of the intake...I know that could be disastrous but there isn’t any in the oil or when I pulled the plugs I didn’t see any there. Is it possible the way I poured in the anti freeze that it got into an open exhaust valve and that’s why it was in the EGR passage?
Any help or suggestions would be appreciated I plan on working on it all day tomorrow, but at this point don’t know where to start.
I also noticed that when I put the transmission in neutral I don’t get the clicking like it’s not able to start in neutral...maybe transmission issue too? Big problems
