Installed Belltech 2/4 Problem with E brake cable
Dustin.
Anyone have problems with the e brake cable rubbing against the air shock on the drivers side rear after installed the shock extenders? Is there anything I can do to fix the problem. Did a quick search and didnt see much about it.
Dustin.
Dustin.
Maybe I need to switch it over on the other side of the shock it is wrapped around it pretty tight I don't know how I could zip tie it
Sent from my SAMSUNG-SM-N900A using Tapatalk
Dustin.
Dustin.
I meant to snap some when I was at the office. I forgot, I'll take some later on.
Dustin.
Dustin.
Ok here are the pics of the drivers side
NORCAL SS
SUV SUSPENSION GURU
Yup normal i attach to lower shock extender with zip ties for years no issues.
Dustin.
Dustin.
ok thats what ill do then. It just seems really tight and I didnt want it to pull on that cable too much.
Also the djm bump stops and the belltech together are what i was supposed to use right? Or should I trim the oem bump stops and use them with the djm ones.
NORCAL SS
SUV SUSPENSION GURU
cut bracket off frame and put my bumpstop on axle hole
lfh2indiana
