yes but it's not level where it should be, bar should be even with the body, not tilted down. adjust the endlink shorterIsn't this one the most aggressive? That's where mine is.View attachment 415592
Got it! Thx Wes.yes but it's not level where it should be, bar should be even with the body, not tilted down. adjust the endlink shorter
I - read - the - directions - an hour agoGot it! Thx Wes.
yepAny of you have the front sway bar also??
Make sure you use a silicone grease inside the bushings where the bars will move. Anywhere there is a new rubber bushings with moving metal inside of it, grease it.My Christmas gift to myself, just got more expensive....... Great..... thanks a lot......
I did, mine are already squeaking.Make sure you use a silicone grease inside the bushings where the bars will move. Anywhere there is a new rubber bushings with moving metal inside of it, grease it.
I think a set of front and rear bars set me back $600.My Christmas gift to myself, just got more expensive....... Great..... thanks a lot......
I slathered it on. Plus, you operate where there is salt on the roads, correct? I would have to disassemble to regrease that way.I did, mine are already squeaking.
I usually have to re-grease mine every 6 months or spring/fall when the weather changesI did, mine are already squeaking.
So you unbolt the bushings to regrease?I usually have to re-grease mine every 6 months or spring/fall when the weather changes
So,..... the factory sway bar I have with 172,000 miles makes no sounds.... ( that I know of ) You'd think there is a better lube for the bushing that lasts. ( Silicone? Lithium grease? ) Maybe Hellwig has a solution?I have done it once. My friend and I have been planning to tap the collar and install a grease zerk and drilling a hole in the bushing for grease path and then also channel the inside of the bushing for grease disbursement.
hellwig sends them with a small packet of I think silicone grease, mine have always made noise every so often even with oem might have something to do with evironmental conditions or my driving.So,..... the factory sway bar I have with 172,000 miles makes no sounds.... ( that I know of ) You'd think there is a better lube for the bushing that lasts. ( Silicone? Lithium grease? ) Maybe Hellwig has a solution?
ya takes like 10 minutes and done, just the D bushingsSo you unbolt the bushings to regrease?
I think with our winters, after a few times the bolts would probably snap.ya takes like 10 minutes and done, just the D bushings
they should be stainless, if not head over to ace hardware and match some upI think with our winters, after a few times the bolts would probably snap.
