I need help please on abs- **SOLVED**
Num12005
Num12005
Oh i can tell if it has sensors in the rear and ill say it again, it doesnt have rear abs sensors. Ive changed the rear end just last year, i have the rear end out and 100% visible, no sensors. The only yhing ive had to wait on is the codes. Transmission is probably already fried as i drove it that way to get home. I can def tell it got worse and worse..
Num12005
Num12005
If the speed sensors have issues it can cause all kinds of trouble including going into limp mode where the trans won’t shift. I’m not sure if it does that for just ABS issues but the speed sensors will cause ABS issues so it’s all tied together.
I tested the front sensors and they put out the rquired milliamps, took em out and cleaned them also. I changes the feont bearing hubs 2yrs ago i can confirm from receipts, they are timkwn fron rockauto. Now that im not in such a bind for a ride ill just have to wait till i get my cousins scanner and see what that reveals. I was just curious if the abs module could cause the trans issues? Friend of mine said that a bad module would not affect the trans but ive read online where guys had the same issue and the abs module fixed it... anyways like i say, i really appreciate the help!
afpj
Oh crap, I can't read.
corvette744
2004 Z-71
Northern illinois
From what i have read the rear abs on your tahoe gets its signal from the vss in the transfer case.4wd top left of transfer case .2wd left rear side of transmisson i bet thats your problem.Again just go to autozone it will take 5 minutes and they will give you the code.Buy a new vss if thats the code takes 5 minutes if that to replace.I have to add talked with my chevy tech buddy he said sometimes they dont throw a code also-just have similar problems like you have.
exp500
P0500,P0501,P0502,P0503. Look at post 14 again, And post 24. Then scan your truck!
Num12005
Num12005
View attachment 281110 From what i have read the rear abs on your tahoe gets its signal from the vss in the transfer case.4wd top left of transfer case .2wd left rear side of transmisson i bet thats your problem.Again just go to autozone it will take 5 minutes and they will give you the code.Buy a new vss if thats the code takes 5 minutes if that to replace.I have to add talked with my chevy tech buddy he said sometimes they dont throw a code also-just have similar problems like you have.
Awesome thanks for the schematic, ive already changed the vss in the trans and still the same issue. Now that i have the layout ill start removing loom and testing wires.. im afraid to drive it to our parts store as it only runs in second and thats a 40mi round trip. I should be getting a snap on scanner loaned to me soon, codes would help alot if it has them. Also i see on the schematic its suppose to have a fluid level sensor, once again mine doesnt have one. I wonder if it being a ppv with hydroboost setup has something to do with it. Ill keep everyone informed on what i find, REALLY appreciate the help
corvette744
2004 Z-71
Northern illinois
Ok so you have a 2wd vehicle then right.Here is the rest of the diagram
Num12005
Num12005
I sent the brake module off to Abs fixer and he said he found 4 codes 1- 0236 and 1-0265 and 2 communication error codes in the history, so he replaced the relay and re soldered all of it, its in the mail back to me. Guess we will see..Here is exactly what he said
Module had 4 Codes in history. C0265, C0236, and 2 communication codes. None current. Removed excessive solder from a previous repair. Replaced relay. Reseated multiple solenoids. Tested OK. Could not reproduce faults. All OK Reset and cleared codes.
exp500
Glad you are making progress. Some codes are tough. If you get any more faults, look at/test grounds.
Let us know the results.
Let’s hope that fixes it!
corvette744
2004 Z-71
Northern illinois
Rear sensors are in the axle I believe. Near the wheels.
No their not sorry-gets signal from vss in trans for rear input-i think that fix in your module should take care of it.If it had that many problems and you changed the vss already if not.Get ready to track down wiring.
Num12005
Num12005
I will know next week as im in Key West at the moment.. i definitely will post the results, i have my fingers crossed cause i wiring problem solving isnt my strong point, lol.. thanks again for all the help..
YukonRog
Auburn, CA
OP has '05 Tahoe right? They're in the axle on my '05 Yukon. (see pic) And here's also a illustration of an '07. We talking about the same thing?
Num12005
Num12005
Ok, just installed the repaired Abs module and nope, still the same crap.. Man, i dont know..
PexoA78
