How to install amp/sub into 2000 OBS denali with Bose??
billbies
New to this truck and have installed many systems just never into anything with Bose
I have an amp and 12" sub I want to install
I know the bose amp is under the console
Just curious where I get my pick up for my RCA's and remote wire?
Any help is appreciated and also can I install an Aftermarket HU like normal or would I have to rewire all speakers?
Thanks
B
billbies
thank you for the reply
is it best to run off the outputs at the amp or of the harness behind the HU
Direct me to a wire chart for the correct wires to hook up line out converter to?
Which wire is best to use for remote wire?
Thanks for the help
B
billbies
Thanks for the reply I have one in my hands
Where is the best to get the signal behind the HU or get it at the bose amp in the center console???
Thanks
jdpber
GOLD MEMBER
The America
you can do either.. its the same signal
i have wired cars both ways..
---------- Post added at 09:30 AM ---------- Previous post was at 09:29 AM ----------
at the bose amp may prove to be the easiest as you will have less wires to work with.. its all up to you .. personally i prefer behind dash so the box is hidden in the dash
B
billbies
if behind dash what wire for the remote lead do you tap into
Thanks for the info
jdpber
GOLD MEMBER
The America
your going ot need a multi meter.. or a signal light.. and find a hot wire when ignition and radio are on.. that is cold when ignition is off..
B
billbies
ok thanks didnt know if you knew right off the top of your head
CKendrick
