home made sub box
96Chevy
can someone tell me what kind of wood i shoud buy for a sub box. becuz this summer im going to attempt on making one my self.
any tips??
thanks in advance.
96Chevy
96Chevy
what is mdf??
does it stand for something??
or is that what the wood is called??
josetizapan
Iowa
It stands for Meduim Density Fiber wood. One tip i could tell you is pick the subs that you are going to use and check the manufactures recommeditions for the type of box and the volume and also the port size.
96Chevy
96Chevy
so THE BEST is 3/4' ??
---------- Post added at 08:40 PM ---------- Previous post was at 08:40 PM ----------
or does the thickness even matter with the sound quality??
and i also want to know what gives a solid sharp beat/bass??
josetizapan
Iowa
I think 3/4 should be enough the reason is if you use a 1 inch its going to be heavy and unless you going with powerfull speakers and amps its not worth the weight that's my opinion.
2drhoeon4s
yeah 3/4 is very common. it will do the job fine for most builds. I money isnt an issue Id go with Birch. 3/4 inch. It is sold in 4x8 sheets also. It is lighter, stronger, and doesnt split like mdf when you put a screw in its side.
96Chevy
96Chevy
Is birch another kind of wood??
And that another thing I want to know?? What's the most common way to put a sub box together?? Nail gun?? Glueing?? Screwing?? What?? Or am I missing something??
And what makes a sharp and solid bass??
Thanks
96Chevy
96Chevy
what subs do you guys recommend??
---------- Post added at 06:31 PM ---------- Previous post was at 06:30 PM ----------
what brand??
SPLmonster13
Texas
Sub brand is like asking who likes nike or addidas, personally i like Rockford and Soundstream and the companies they own. MB Quart and Power Acoustik.
Jaycenk
Florida
You need to pick a sub, amp and box design that will all work together. thats the secret to great sounding subs. If you buy a sub that wont work well in your box it will never sound good no mater what you power it with. Go look at them and look at thier requirments. First you need to figure out where the box is going to go and how big it is going to be. Then you look at speakers and amp to find out how much power you can afford and what speakers you can afford for your box design. You can make a cheap ass sub sound good in a properly designed box and amp combo.
AdrienR
