High compression question
ajgreen
Hi, New here but not new to car problems. Here's the latest. 1999 Yukon 5.7L. I'm chasing a P0305 missfire. Changed plugs, wires, cap and rotor. SES light came back in a day. Yesterday I pulled all the plugs and did a compression test. All cylinders were between 190 and 200 PSI! I checked a couple with another gauge I had and it actually read a couple PSI higher. My first guess is carbon buidup. Anybody else want to guess?
vacuum leak/intake leak?, double check the work you did, if it ran fine for a day then maybe something failed already that you replaced., do you have a scanner that can read live data?
A
ajgreen
Double checked everything, all is good. I assumed a vacuum leak would give me a lean condition error which it does not. I have an old scanner that will give me live data. What should I be looking for in the data stream?
I would start with monitoring the misfires and see if that points you anywhere specific, like if there consistent on certain cylinders or just all over the place random, I haven't had a obs in a long time but don't those have a coil? or is it all in the distributor? I think it's called HEI? maybe the distributor has issue's? like I said it's been a while, maybe @swathdiver or @07Burb may have some idea's
A
ajgreen
It does have a coil. But, I did cheap out on the tune up. it has an after market cap and rotor. Think I'll get an OEM part and see if that helps. I also read somewhere that the distributors are all made of plastic! I wonder if it's worn to junk?
Well cheap parts would explain a lot, lol I would at least get a decent cap & rotor, like borg-warner or ac delco, but borg warner probably makes them for delco anyway.
bigfootchiro
Largo, FL
Didn't Nathan go through this before his big block swap? @bigfootchiro
Oh yes indeedy! So my answer to solve all issues is big block swap lol.
Alright, so you have a Cylinder 5 misfire. Good job on compression testing. How many miles does the motor have? How long has the misfire been happening? Did you do anything just prior to this happening? The code only sets once the misfire counts go above a certain number.
You can have a vacuum leak and not have a lean condition code set. That code only sets when the fuel trims go way into the positive range (above 25 I believe, someone correct me if I’m wrong).
Definitely setup a scanner with live data and look at misfire counts per cylinder (history and current), CMP Retard (should be between -2 and +2), short term and long term fuel trims for Banks 1 and 2, RPM, aaaand I think that may be it for now... try that and report back with some numbers at Idle, 1500, 2500, then while driving, as well. If you don’t want to keep an eye on the scanner while you’re driving, record your screen if you have an iPhone.
A
ajgreen
Don't have such an advanced scanner so may have to take it in to someone who does. Truck has 178K miles. Had the missfire code several weeks ago before I did plugs etc. Came right back.
Nobody has addressed the high compression. With 190 to 200 PSI wouldn't it ping like crazy on regular gas? Compression ratio would be 13:1!
bigfootchiro
Largo, FL
Don’t need an advanced scanner. You can order a Fosseal WiFi OBD2 on Amazon and use DashCommand app. Buy the $10 add on pack for your year inside the app, and you’ll be able to read everything you need.
I would double check compression with another tool. If they are ALL between 190-200, that’s some pretty equally distributed carbon deposits lol.
Any chance both compression gauges are inaccurate? Unless I need to know the actual PSI of the cyliners (which then I'd use a known accurate gauge), I use compression gauges pretty much just to get numbers for comparing all the cylinders to see if any have a considerably different reading, regardless of the actual number. A failed injector could cause a misfire, it's not just an ignition-related issue. Unless your '99 has the injectors replaced/upgraded to the newer injector setup, it'll have poppet nozzles with a "batch fire" injector pod. The fault could be within this module.
SUBURBIAN
All Chevy
Cranking compression is subjective and not directly proportional to static compression. In other words 190 to 200 psi of cranking compression does not indicate 13 point something static compression. Internal engine measurements and cam timing, even battery and starter "strength" determine static compression. Cranking compression is more of an indicator of an engines health and snappiness. 190 to 200 is normal for an L31.
A big question here is the condition and type of injector spider. Poppets leak and can cause the black box to think misfire. Same for the distributor. The drive gears knife edge from wear and can allow enough slack with the cam to misfire. These may be where the problem is considering the even compression readings.
What injection setup is in it, the older pressure actuated poppet setup or the newer electronic setup?
Have you ever changed the distributor gear?
And otherwise, that engine really needs oem ignition parts to work right. They just don't run right on anything else.
If none of this solves your problem you might check the health of your fuel system.
A
ajgreen
Well, I took it in for a diagnostic. They told me it was a bad intake manifold gasket. They quoted me $1500! I ordered a gasket kit and an upgraded spider injection kit for $300. My weekend will be shot.
SUBURBIAN
All Chevy
Which gaskets? If they arent the rubberized metal gaskets send them back.
dizhai
