So I have a squeeling noise that just started. It happens under light accelleration at low RPM. if i let off the gas or accellerate hard, the noise is gone.
I got under the it and removed the rear drive shaft from the rear end. The rear end is quiet. With the tranny in neutral, engine off, I can turn the rear drive shaft (still disconnected from the rear end) slowly by hand I can hear the squeel coming from near the transfer case, possibly near the rear of the tranny.
If i remove the rear drive shaft from the transfer case, there is no play in the Transfer case output shaft. The Transfer case has the proper fluid level and works good, as does the tranny.
Any suggestions, similar issues, known problems like this.
All help is appreciated!
