Heavy Duty Tie Rods?
Matthew Jeschke
Sahuarita, Arizona
I drive on old forest roads a lot with my truck. I am curious, do they make a decent yet affordable heavy duty tie rod? I see a couple brands but they're around $300. Or do the HD trucks have better tie rods? My 2001 Z71 looks like they put pencils on for tie rods.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I went to order them on Amazon and it mentioned people were not liking the boots on that inner tie rod. Then watched a review on youtube. It doesn't seem much different than the factory tie rod. Maybe I'm fine with factory ones... These are the ones that caught my eye but seem damn expensive for a tie rod: HERE
This is another set but just looks like fancier machine work: HERE
I just pulled from Amazon. I think they make versions that fit the tahoe, but I believe those are for the Duramax, or maybe duramax parts work on the tahoe not sure.
HiHoeSilver
Away!
Chicago
I'm pretty sure they make them. The Rare and Kryptonite stuff is both pricey and beastly, that's for sure.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Pricier can also be because they make way more of the standard ones when they tool up to make them and they make less of the H/D ones so tooling up gets more expensive in the long run plus the extra cost of the materials.
TheAutumnWind
They make sleeves that beef them up for way less money.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah I saw those sleeves. Looked kind of gemicky.
Curious, are the 2500 or 3500 ones a fit for 1500 chasis... ? If so are they a better part?
Sent from my SM-A505U using Tapatalk
TheAutumnWind
Adds support to the weakest part. Not sure what's gimmicky about that.
It's that or $250 for rare parts brand or 300+ for heims and dom.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah but it is still weak at ends... honestly though I am search and ppl seem to like the sleeves. Maybe they are the best option.
TheAutumnWind
The ends are not the typical failure point. I mean sure they wear out but that's not what breaks with big tires or launches.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Makes since. Probably the most reasonable route then is a nice moog? The proforged part had some bad reviews with the boots and joint. I'm going to keep an eye on the rare parts thought to see if I can snag a set of returns for cheap lol
TheAutumnWind
IIRC for some reason the MOOG problem solver inners are just slightly too big for the sleeves. Might want to look into that. Maybe AC Delco pro + the sleeves is a good bet.
MaBs413
NJ
I have the rare parts tie rods in my 03 Yukon Xl... They are awesome.... i found out about rare parts on this forum...
TheAutumnWind
They definitely look great, I am curious about the ROI. You think there is a noticable difference for the driver compared to a quality set like ac delco pro or MOOG problem solvers? I'd imagine yes if you are running real big tires, but at stock or lowered I am skeptical.
AZGOAT
SO. ARIZONA
yea i tired of the match stick tie rods aswell so im doing alittle upgrading
Korbin_A
