Haven't seen this before
Mpsw9mm
Went to change my tps today and this is what I found anybody know where to get this style.03 Denali xl 6.0
wjburken
Eastern Iowa
Went to change my tps today and this is what I found anybody know where to get this style.03 Denali xl 6.0View attachment 244631
Welcome to the forum from Iowa.
RockAuto has what you need I believe.
RockAuto.com is a great source for parts. They are also a sponsoring vendor. Should check out their thread in the vendor section.
Mpsw9mm
Mpsw9mm
Look inside that one if you can I ran into this problem nobody can find it on their computer at the parts stores or even seen one like this..notice the circuit board and dials with numbers it is adjustable or something and the two plug in connection are in different spots.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum from Oregon.
We recommend that you put all your rig(s) info in your signature so we all don’t have to guess at year, make, model, engine size, trans, rear axle locker…….etc. Makes it way easier on all members that attempt to help, to have that info right up front. It is also recommended that you take a pic of your RPO codes, on the inside cover of the glove box, and post that image in your signature. All this info will greatly help those that will try to help with a problem.
If there is any other info, like upgrades, mods or recent mechanical/maintenance work done, that would be helpful in any post as well. Too many times a question is asked by the poster and after about 10 responses we find out that the poster has done recent work to attempt to fix the problem or work that was done that SEEMS not related to the problem.
Mpsw9mm
Mpsw9mm
W
Whole throttle body. And a pigtail.
Kinda what I figured lol... probably have to get it programmed also...thank you
Scottydoggs
NJ
i wonder if you could clean that up with some rubbing alcohol and some q tips.
either the junkyard if your lucky and find one that will sell it separate or just buy a whole used one from them
the one you bought and doesn't fit is the only one available and is the same for the 4.3, 5.3, 6.0, 8.1 liter 1500, 2500, 3500
Mpsw9mm
Mpsw9mm
Yeah I know I had a 04 Yukon 4.8 took the normal one...just have to order a whole new throttle body assembly ...thanks for your info
Moderator
People's Republic of Colorado
I don't really know any more than what I've seen on YouTube, and I might be seeing things, but your old one looks like it might be from an NNBS.
Mpsw9mm
Mpsw9mm
As far as I know it's the original engine 6.0
Moderator
Might check with your parts guys on the off chance the TB's been changed. Shot in the dark.
EDIT: @Mpsw9mm, my observation was based partly on the configuration of the two connections at the narrow end of the part. Does your part, or the TB, have any numbers on it?
vsaravia
