Get a catch can before any mods.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
a hour to install a catch can?
from the time I took it out of the box and bolted it up was 5 minutes. Then again I do intake manifolds/headers/cams on trucks a lot.. hell going on my 4th cam swap this weekend on my ctsv prob will take 2 hours from start to finish. Even for a person buying a catch can for the first time I can't see one hour but if it takes you 1 hour all good better than a shop charging you $$$ on a product you can install yourself
D_R_C
I'm pretty sure I explained why I spent one hour, instead of the normal 20-30 minutes on a basic one shot install with everything cut and ready to go. 5 minutes from out of the BOX :sorry: BS meter just broke
It was 2 minutes now its 5 minutes anyone that has installed one KNOWS BETTER.
I think we all appreciate the info you supplied but what your claiming will never and has never happened.
I might be a newbie on this forum but I've been around for over 60 years working and maintaining just about every type vehicle including racing for over 20 years when tuning was actual mechanical tuning.
Not this computer programming stuff.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
its a easy install even for first timers. Do it guys even if it takes 10 minutes and if your in northern cali and scared to do it come by my place I will install it for free. 5 minutes of your time is all I need.
D_R_C
FOR EVERYONES INFO, The Catch Can new out of the box is NOT ready to install.
The 4 Brass fittings are loose all 4 needs to be removed and then you need to put a good quality thread sealant on the threads then re-install and tighten them up.
Plumbers tape or plumbers paste does not hold up well with the high temps and oil.
You also should unscrew both ends of the catch can and apply light oil or grease to the rubber oil rings then re-install.
This alone will cost you a few minutes out of the install time, from the time you open the box.
tights24
Thank you both for the info. I will check out the DIY soon.
As for the amount of time it takes to do the work, who cares. Why get bent out of shape if someone says it takes two seconds. It's a figure of speech, and my guess is that Tony mentioned 2 minutes or 5 minutes merely to explain to folks that it's not an all day event. Let it rest already.
ezdaar
Chat Troll
Redneck central, Aka Houston
Sheet! you guys are slow, By the time you un pack yours, I already un packed and installed mine..
Took me 1.2 mins and was driving down the road doing a burn out.
You guys are the suck! :pepper:
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Teflon tape works great. No issues and have had it on for 5k miles now
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Doing another oil change on customers truck on sunday ill take pics of how much oil comes out of the cap.
germantown tn
"Also you have to remember the compressor air line filter is made to trap moisture in the air line, NOT oil."
That's why the filter element was replaced with the blue a/c material. It won't clog up with oil and allows it to drop out to the bottom of the cylinder.
It's been working successfully for two years now.
---------- Post added at 02:57 PM ---------- Previous post was at 02:53 PM ----------
If you want to check how good your can is working, be it a cheap-*ss made-up one or a mega buck for show billet one you have to polish, add one of those see-through inline fuel filters into the line from your can to the intake manifold. If it collects any oil, your can ain't so good as it could be.
Where do you get the blue a/c material lowes/home depot?
-bigwhite4door901
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
edit cancel on sunday prob next week. I'm in TN lol
Juamgv
