Get a catch can before any mods.
adventurenali92
Big Bear Lake, ca
So forgive me if this has already been asked as I'm still learning alot about my Denali. And now im starting to do mods under the hood and I want to do mods that help my motor run as efficiently as possible since my 2006 denali XL is my daily driver for my detailing business as of right now. Would a catch can work on a 2006 denali 6.0?
redeknightjr
Yessir
1SG Retired
adventurenali92
Big Bear Lake, ca
@redeknightjr , thanks for the response! Ordering a trans cooler right now and then im gonna pick up a catch can. Gonna make it easy and order one from the link he posted. Will it come with everything I need or do I need to pock up extra hoses and fittings?
redeknightjr
You will have to get the hose, hose clamps, and thread lock brother
1SG Retired
Drok
Cold place in the north
Ive had a catch can on my 05 since 2009 it's worked out great, the intake ect were cleaner then the first time I changed a knock sensor. And today I just took it off the 05 to put it on the 2010 I got a couple days ago :)
Larryjb
I just made my own using the following compressed air filter:
https://www.lowes.ca/air-tool-accessories/kobalt-38-in-air-filter_g1186695.html
In about 1000 miles I collected a couple of ounces of oil (about 1.5" in the bottom of the home made catch can.
However, the plastic innards partially melted from the heat. I'll try to mount it farther away from the engine block. This is really too bad because this $40 in air filter seems to have done as good a job as the $100+ catch cans. I may just have to bite the bullet and get one if heat continues to be a problem.
NGAneer
NWGA
I used a Husky compressed air filter from Home Depot. Only one I could find that was all black (mine didn't have the stickers).
Mounted to the driver side of the alternator bracket and has done great since. Where did you mount yours? I've experienced no heat damage at all.
Larryjb
It was sitting just behind what looks like a battery 12V+ junction on the drivers side, so it was just above the valve cover and exhaust manifold. Your location probably keeps it cooler because of the radiator fan.
I just took another look at yours. Mine is just behind where you located yours. I guess those few inches make a difference.
NGAneer
NWGA
Very likely. When still, the heat from the exhaust would be concentrated on the sides of the engine above the manifolds. When in motion, the heat from the manifolds being blown backwards would keep it away from the front of the engine. The material the filter is made out of will make a difference too, different plastics melt at different temps.
Jason_S
For $25 something like: http://www.ebay.com/itm/BLACK-SQUARE-ALUMINUM-BILLET-HIGH-QUALITY-OIL-CATCH-CAN-RESERVOIR-TANK-CHEVY-/371774688378?fits=Make:Chevrolet|Submodel:LS&hash=item568f7f8c7a:g:-cYAAOSwcUBYEqrO&vxp=mtr would work fine. I m running a similar design with a plastic scrubber inside. Like this: http://www.tools2parts.com/3M-215FW...1phxk1_BDX3TdXwjzQNJ34uRoCRu_w_wcB&click=1006
I reworked the fittings because they were a soft aluminum instead of being brass, and then mounted it up front above the power steering pump/reservoir.
Meccanoble
Georgia
loving the custom more affordable options. Very interested in how they have been working for everyone. I was looking to get an intake instead of just replacing my filter but wanted to make sure it was worth it since thats the only performance mod i'll probably be doing (besides muffler). Will work on this first and even check to make sure intake alone is worth the $
NGAneer
NWGA
I get at least a few tablespoons each time I change the oil.
jdpber
GOLD MEMBER
The America
buy a true can it will be a life saver. so much easier to empty
Drok
Well I finally had time to swap it over today. :D
BadDaddy2003
