Funky Transmission Issues
BigBlockJacen
ok group, long message incoming
Here is a puzzler for you but hopefully someone has had this happen. I had a new transmission installed last year in my 2002 Yukon with the 4.8l engine and it came with a 1 year warranty from a very reputable shop. A month before the warranty was up...the transmission started having 2 issues. 1) When you reverse out of the driveway, stop and place it into drive, there is a big delay and if you give gas too early, it thumps and jerks you into your seat. 2) The transmission shifts fine from first into second however the transmission will not shift from second to third when over 2000 rpms....under that it will shift fine. I took it back to the transmission shop and they have been great trying to fix it. At first they changed out the servo...no change. Changed out another servo and also the valve body...no change. They kept my my truck for 2 weeks and placed not 1 but 2 transmissions in it and it still did the same thing. They were now confident that it was not a transmission issue. They called a mechanic shop the owner knows that works on GM's and he said it sounded like the throttle body and to send it to him....they are known to cause transmission shift issues. I took the Yukon home and decided to do one thing before thinking of changing the throttle body...I installed a new Throttle Position Sensor on it to see if that might fix the issue....guess what....it STILL does the same thing.....thumps from reverse to drive and will not shift from second to third when over 2000 rpms. I took it to the mechanic shop that was recommended and after a week or so, he told me that everything was fine and it had to be the transmission....he even called the transmission shop back and told them it wasn't the engine.....I am at a loss. Has anyone ever experienced this? I have been down a vehicle for months. Do you all think it could be electrical?
Thanks everyone.
I’d be willing to bet it’s the transmission and when that shop told you they replaced it two more times they were lying, they probably are trying to get you past the warranty period. Take it to another trans shop and don’t mention that you have had it worked on at another shop until after they give you a diagnosis. If it’s electrical, there will be codes stored that they can read. If they do tell you there’s codes, have them write them down. Even if it’s mechanical in the trans there should be codes. Then go back to the original shop and have a little talk.
BigBlockJacen
BigBlockJacen
There are no codes that refer to the transmission. That is a good idea to take it to another shop.
rockola1971
Indiana (formerly IL)
Sure sounds like you have a valve sticking in your valve body OR a seal leaking past OR a check ball sticking in your tranny separator plate (Common problem of a worn transmission, the checkballs will peen the contact surface of the separator plate and get stuck there).
What color is your tranny fluid now? Nice and bright pink or more of a orange-brownish? Does it smell burnt?
Welcome to the Forum from NH.
Pics of the truck, please.
Be glad that this happened BEFORE the warranty gave up.
Well..it first started acting up a month before the warranty was up, then they said they changed a servo, then they said they changed out another servo plus the valve body, then they kept it for two weeks while they said they put 2 other transmissions in it (cough) and it’s still not shifting right. I’d be willing to bet the reason they kept it for 2 weeks is to let the rest of the warranty expire, which will be their next move. Also I notice he said he’s been down a vehicle for months which probably means the warranty is now over. @BigBlockJacen is that shop still willing to warranty it?
NO 2-3 SHIFT OR 2-3 SHIFT SLIPS, ROUGH OR HUNTING
No 2-3 Shift or 2-3 Shift slipping, Rough or Hunting
Oil Pump (4) Stator shaft bushings scored or off location
Valve Body Assembly (60) 2-3 Shift valve train stuck
Gaskets or spacer plate incorrect, mispositioned or
damaged
2-3 Accumulator valve stuck
Face not flat
Chips in servo feed oil, orifice #7 in spacer plate
Mislocated valve body to spacer plate checkball or
checkballs
damaged
Face not flat
checkballs
But they tried 3 different transmissions and they all did it!
csan2879
