2008 5.3 FF hard starting issue
mxking1712
hello everyone. im having a issue with my 08 tahoe. 5.3L flex fuel engine
Ill try to list everything ive done or looked into thus far
engine sometimes starts just fine, other times it turns over maybe 5 or 6 times before it stumbles and eventually starts idling, other times its like it starts too soon maybe the first crank or crank and a half which also causes it to stumble and then idle normal. It seems if i hold my foot on the accel pedal just slightly. this issue is less prevalent.
Now onto what ive tried so far...
when i bought the tahoe 2 years ago i changed plugs, wires
at first i believed i had a ad fuel pump, as fuel pressure would slowly bleed off and figured it must be the check valve inside the pump. replaced fuel pump with no change... then also replaced fuel pressure reg on the fuel rail with no change...
i have removed throttle body, cleaned that, and also did the relearn procedure...
now onto what i think is the issue but im not sure how everything works... Fuel pressure with vehicle idling is around 58psi, which i gather is normal, fuel pressure does slowly bleed away when vehicle is off, which also seems normal, however every time i cycle the key, the pump does not run... i have seen fuel pressure down as low as 20psi and its not until the engine is actually cranking that the fuel pressure comes back up... so it seems like sometimes when key is in run position the pump runs, but other times it does not.... should the pump run every time the key is cycled? is ignition switch telling the fuel pump relay to go when the key is turned?
what controls fuel pump once the vehicle is running? same relay? or something else?
i have tried swapping the fuel pump relay also with no improvements. sorry for the long winded post but figured the more info the better. i cant find much online as far as the same issue im having. thank you
fpcm fuel pump control module, replacing it requires a relearn with a tech2 or similar scan tool
These motors run at 43.5 psi. The key on pressure goes to about 50-60 psi and is not supposed to lose more than 5 psi in one minute.
Have you recently checked the plugs to see if the injectors are working properly and not bleeding down? Have you signed up for the shop manual at AllDataDIY and run through the troubleshooting guide? Without the manual and Tech-2, you're running blind.
wsteele
I didn't think your MY had a fuel pressure regulator on the fuel rail, I believe it is in the pump assembly.
Key on engine off, the pump will run for a short period to assure prime. I don't think it will keep coming on with each key on/off cycle.
You fuel pressure seems off when idling. With the 2008 and up models, your pressure is controlled by the FPCM (aka FPDM, etc.) and should be as @swathdiver indicated at 43.5 PSI.
Dorman sells a preprogrammed plug and play FPCM. The FPCM is located right under the drivers seat facing forward on a frame rail.
Welcome to the Forum from NH.
Pics of the truck, please.
M
mxking1712
thanks guys, when i get some time i will re check the fuel pressure, its been a while since i played with it, i could be remembering the wrong number there. my biggest concern is the fuel pump not kicking in with key on engine off all the time. i understand it shouldnt do it back to back to back. but i am pretty concious when im driving it to listen when i start it up. i do hear it sometimes, but not all the time, when i dont hear it is when it struggles to start. Im more so trying to figure out what makes the pump kick in when i turn the key.. sounds like the module..
wsteele
You might double check my math on this one, but I think you don't even have a fuel pump relay (should be an empty spot in the main fuse/relay box on the drivers side of the engine compartment) as the pump control is centered in the FPCM (aka Fuel Pump Drive Module). I believe everything from 2008 on is like that.
M
mxking1712
So a little update. I ended up ordering a New fuel pump control module through the dealer. Had them program and install. Did not fix my issue.
I do not have a fuel pressure gauge(yet) however I have a decent Autel scan tool. When I hook into the truck, I get a desired fuel pressure of 58psi when key is in run position, once engine running this drops down to 43 desired and the pressure matches.
When i turn the vehicle off, fuel pressure climbs, I’ve seen it as high as 80psi.
If I shut Tahoe off and on over and over back to back, it starts perfect every time. It seems as though once the fuel pressure comes way up to 80psi and then starts to fall again. Takes around half hour to start slowly creeping down, is when the hard starting happens. Is it normal for fuel pressure to go that high?
If I have a weak injector, when I go to start the car after fuel pressure being so high. Could it possibly flooding one cylinder out and causing my poor start? Anyone have any ideas?
M
mxking1712
Last post for tonight.
I went and drove the Tahoe around for about an hour. Came home shut it off with scan tool plugged in and monitoring fuel pressure sensor.
After about 15 minutes of sitting pressure was up to 80psi
It held there for about 20 minutes and started to drop.
After another 10 minutes I was down to 55psi
10 more minutes took me to 34 psi. At which point i tried to cycle the key but the fuel pump did not run.
10 more minutes down to 28 psi. Cycle key no pump
10 more minutes 17psi, no pump.
I then tried to start the truck, which it turned over about twice as long as it should before it stumbled to life for 2 or 3 seconds and then found a smooth idle.
I do not understand why the fuel pump does not run under 58psi
The scan tool tells me the desired pressure when key on engine off is 58 psi. Shouldn’t the pump run anything below 58?
I really believe this is my trouble here and I have no idea why the pump won’t run. Sometimes it runs just fine and starts great. But this being intermittent is driving me crazy.
BG1988
so how old is the battery?
highest i have seen my FPR was 90PSI(according to the computer) normally runs 44PSI while running
I would check the fuel pump relay swap with another with the same numbers on top..
on the start up issue try cleaning the MAF sensor(could also be bad) spark plugs cables ignition coils compression
M
mxking1712
Battery 3 years old. Tested with another battery last night no change. There is no fuel pump relay in this truck. 20 amp fuse under the hood and then down to the fpcm. I have 11 Volts at the module, 11 bolts on signal wire coming from ignition. But after the module there’s no real way to check without pulling tank down again. I wish someone knew the answer to my question. When the fuel pressure is below 58psi why doesn’t the pump run. In my mind if I shut vehicle off abd fuel pressure is above 58 sure the pump won’t run. But after sitting and losing some pressure pump won’t run again. Sometimes it does sometimes it doesn’t. I checked the two grounds(one at module and one by the pump) both checked good. If someone actually knows how the fpcm and ecm work together that could explain it to me, that would be greatly appreciated
M
mxking1712
I should also add, I did some research on these injectors and the oil sending unit. The way I understand it, when you turn key on, fpcm sends a signal to prime fuel system. Once that is done, engine cranking starts to bring oil pressure up and this is what keeps pump running continuous is that oil pressure signal.
This almost makes sense with my problems, with fuel pressure around 30psi for example, my pump won’t run, engine starts to crank and injectors don’t open(sounds like they won’t open with less than 50psi initially) once oil pressure starts to come up under engine cranking, fuel pump kicks in, and it starts up.
wsteele
I think you lost me.
I will be honest, it is really hard to stay in here with you. In your first post you said you changed the fuel pressure regulator on the fuel rail, but your truck doesn't have a fuel pressure regulator on the fuel rail. Then in that same post you said you swapped the fuel pump relay, but your truck doesn't have a fuel pump relay.
The symptoms you describe pretty much land on either the FPCM or the Fuel Pump (which has the fuel pressure regulator in its main assembly), so the two most likely candidates have been replaced.
The only thing I can offer is maybe one of the two components that likely are your problem, when replaced, were not functional. But I will say, it is pretty long odds that the new unit (either FPCM or Fuel Pump) was DOA in the exact same symptom you replaced it for.
The only other thing that is in the mix (from my perspective) is the fuel pressure sensor. I guess it is possible that it is reporting in error, but that is easy to check. Just go down to NAPA and rent a fuel pressure gauge. The rental actually is free, they just charge your card in case you don't return it. After returning it, they credit your account in full. It will take about 5 minutes to verify your pressure sensor is good or bad, using the analog gauge and your ODB scanner.
Good luck.
M
mxking1712
I will admit I was a bit confused when I first started this thread, I had done some trouble shooting a few months ago, and stopped. When I made the post I had somewhat forgot what I had all done.
When I said fuel pressure regulator I meant purge solenoid on the fuel rail. My mistake.
And onto the relays, I also did not understand about the module until I made this post. I thought the fuel pump ran off the run/crank relay. I have re read what I have posted here the first few posts and I agree with you it would be confusing.
I’m sorry for that.
I appreciate the advice I have gotten so far, it has gotten me to check more stuff and more importantly learn more.
I have a fuel pressure gauge on order to compare with the sensor.
If no one else has any ideas that’s alright, I will eventually figure this out. I don’t like leaving things like this unresolved. Thanks for your help
Edgar1740
Did you end up finding the issue I have the same problem on my 2008 Silverado 4x4 5.3
Fless
Moderator
People's Republic of Colorado
Well, the OP hasn't been here in two whole years, so I wouldn't expect an answer. Might want to consider starting your own thread with some details about your rig, what's been done to it, and the specific symptoms it's experiencing.
ridewot
ct
I just checked the fuel pressure on my 2008 5.3 Tahoe and 56 psi not sure where everyone says it’s supposed to be 45?
What did you check the pressure? If you're using a scanner to check the pressure, it's going to rely on whatever pressure sensor is installed on the truck. If you were to be able to temporary install a secondary pressure gauge, mechanical gauge, you'd be able to verify if you truck's sensor is reporting the pressure accurately.
rdezs
I'm surprised nobody suggested the vapor purge solenoid on the driver side of the intake manifold? It fits the symptoms, and an inexpensive fix. Considering the model year of the vehicle, I would replace it regardless as preventative maintenance.
mikez71
coolant temp sensor another possibility..
Fuel pressure spike on shutdown normal, engine heat on fuel rails. 80psi is the relief valve in fuel pump.
I have a log where I'm coasting down from 70mph to 40mph, TCC locked, and the fuel pressure slowly rises over that 20 second coastdown from 43psi to 66psi.
Deceleration Fuel Cut.
Just added for reference.
This thread is old.. we'll never know the answer!
Probably normal. Cold starts 58psi. Fuel pressure also rises from 43psi when you're on the throttle enough.
Warmed up or cruising should be 43.5psi.
Durobans
