Flat tire
CincinnatiZ
Cincinnati and Miami
So im driving in the GHETTO. I've only had this truck for like 3 months and the new 26 inch rims for like a week. I was driving along when I hit a steel plate that was set by construction workers that were working on the roads... As soon as passed over it i heard a loud hiss and I knew exactley what it was. I get out and my NEW rim is on the ground so im like fuckkk.
Lessons learned:
-Carry thin welled socket for removing lugs.
-The spare tire is LOCKED (with your trucks key) under the truck.
-The jack is hidden under a cupolder
-3rd row seats kill storage.
Sorry I just had to get it off my chest. I miss my 03 Tahoe.
Modded
That Guy
Yeah having to deal with changing a flat with the spare is a pain in the ass on these Tahoes.
Good thing you are not dropped 3/5 like me, then you would have had to put the spare on one of the three tires that were fine, then move the 26" wheel/tire from that area to where the flat originally was (all because the drop spindles are too large to accomdate 17" wheels).
A real pain in the ass!!
denalianyone
NYBlackLade08
New York
Get AAA and the tow that bad boy home for free or have the AAA mechanic do all the work.
macky
i thought 07 and up have 5yr 100,000mi roadside assist, couldve called them
REAL TEXAS TAHOE
WACHOE, TEXAS
Presses OnStar button:
Hello Mr. Freeman
AHHHH, just checking. I HATE CHANGING FLATS ESPECIALLY IN THE TEXAS HEAT. You were in the GHETTO you should have just paid a drug dependent person (crackhead) to change the tire. Make ure your Onstar is active.
C
CincinnatiZ
Yeah I was just in the worst part of the Nati (im sure you saw the riots on the news a few years ago...) The Escalade on 6's wasnt helping my situation any. That tire has less than 1000 miles on and and it cut the sidewall :/ sucks for me.
C
CincinnatiZ
And I just got another one! It happened about 20 minutes ago PLUS I bent the rim AND cracked it! Dont buy U2 rims there JUNK!
My bad luck is unreal. Its killing me. Im about to run this mother fu*$*er into a ditch.
zach2011
Platinum Member
That does suck. Where do you unlock the spare tire at? Is it on the rear bumper cover?
Denali132
Banned
yes, when you pop off your hitch cover you will see a little square plastic piece. pop that off and you will see a key hole. They replaced mine last week all I did was hit the OnStar button and somone was out less than an hour.
C
CincinnatiZ
Yeah pull the hitch cover (mine got stolen) then there is a square cap off to the right of the hitch. Pry that open with u r finger nail from the bottom. Then use your key to open the lock. After that stick the pole with the SQUARE end in - not the one with the hook for the jack.
Thank God I havent got the lowering kit put on yet or i would have been playing musical tires on the side of I-75.
One more flat tire and Im going to put the stock 22's back on forever.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
That sucks CincinnatiZ!
Just curious... What size/brand of tire are you running and at what PSI??
048tahoe
