Finally got around to installing my wheels and tires
DenaliCountry
I think it turned out pretty awesome. Fuel Rebel 20x9 +20 Offset with 295/55/20 Open Country AT3's. Also debadged the Denali emblems on the doors. I will say these tires certainly do "sing" on the highway LOL.
smbty
Did you lift or level? Did you have to do any trimming to fit those tires ?
ProfeZZor X
High Country
What's the height of those tires? Do those tire dimensions calculate to the factory 33" height?
I'm thinking about going with a 35" this time around instead of 33".
DenaliCountry
DenaliCountry
No lift or trimming needed. I have Air ride as well. They are the stock 33" height but slightly wider. The wheels also have a slightly different offset that allows them to sit closer to the outside of the wheel well but the entire setup is close to stock. I did actually swap tires though to a 275/60/20 BFG, not because they didn't fit, but the E load rating tire rode like $#!t.
DenaliCountry
DenaliCountry
The 295/55/20 was the same height as the stock tires at 33". They were slightly wider obviously but close to stock height and width.
olyelr
Elk Rapids, MI
I just put 275/60/20 ko2’s on my work truck this fall. Have been a great tire so far.
csan2879
