Factory antenna above driver for SiriusXM
Venator
Does anyone know if the factory antenna on the roof above the driver will work for SiriusXM satellite?
It's on a 2016 PPV with IO3, no SiriusXM.
I was hoping the antennas are all the same, regardless of original equipment.
Thinking of getting a Roady BT, but would rather use the factory antenna instead of the SiriusXM mag-mount. I know I'd need the iDatalink SAT2 adapter cable.
RoadTrip
FL & MN
I replaced mine due to the backwards water drain design of the 2015. I only saw one model listed for 2016-2020. It’s like 3 antennas in one. Mine includes the leads for XM BUT I had to buy a new cable to extend under the headliner that mated with the new antenna.
justinakay79
