Engine oil light is on????
mnbierman1980
For the past three times I have gotten an oil change about 2 months afterwards the low engine oil light comes on and so I switched mechanics to see if that was the problem and it is still doing it and it says there is 60% life left before I need another oil change but the light is on so does anyone else know why this is happening??? Please Help
stevek
Dallas, TX
Check the oil level per the manual. Add oil as needed. It's normal to burn off a bit of oil between changes
06whitess
Pax River, MD
If you have the "J" CodeFFV Motor, and you are burning oil, take it in to the dealer. There's a TSB to have them install a deflector, which fixes this.
PexoA78
