If you had auto 4wd in the 99 the 97 tcas will not just drop in you are looking at major work on that alone. The tranny should bolt but improvements on it made since 97 that would not be there now may require some pcm tranny perimeters tweaking.
---------- Post added at 10:28 PM ---------- Previous post was at 10:25 PM ----------
Cant believe you tore up a 2dr. ThAts f'ed up.
technically yes but wiring changes will need to be made. and if the 99 had the auto4wd tcase your are looking at major electrical work to make that happens. some on the tranny, some on the engine and lots on the tcase system.
legally it may not be allowed to backtrack the classification engine and emmisions system in your location.
can you at least keep the tcase if auto4wd and just move the tranny/engine block that way there is a minimal of rework involved if hardly any and the pcm would not have so much rework either.
btw you have not actually specified what tcases were in yours and the donor truck. it would help.
They are both 4L60E transmissions, you can see where it says that on the second one half way down the housing. The first one is a singe piece or one piece case as they call it, the second one shown is a removeable bell housing. That probably has a 300mm input shaft and convertor, that is the more desirable piece but if that's the one slipping no matter.
I don't know about later model transfer cases to go and open my mouth here, someone else can help you there.
---------- Post added at 02:32 PM ---------- Previous post was at 02:30 PM ----------
After thought: there were changes with the cooling lines around the same time as when the one piece case gave way to the newer "LS" style. When you look at those two cooling line hookups on the tranny they are in different positions, I bet the line feeding and returning is a different thread ... carry on.![]()
QUOTE]
I am leaning towards this real hard.
Can you elaborate on the 'just move the tranny/engine block' part?
---------- Post added at 05:02 PM ---------- Previous post was at 04:53 PM ----------
I misunderstood at first. I see what youre talking about with the removable bell housing and what not. I thought it was being referenced at the torque converter cover plate.
Not sure if you're seeing the pics backwards or not seeing my full posts.. But I did identify already that the second one is a 4l60e as its stamped on the side of the trans. And after further research the other is as well, it has stamped on it M30. Whats with that?
The cooling lines are in the same location on both trans's.
The top trans photo is from the 97 and it has the removable cast bell housing plate underneath.
The lower trans photo is a one piece and had some stupid flat piece of metal blocking the flywheel bolts.
Also, what about my trans symptoms form the 99? Is the torque converter supposed to be dry and sound like something is loose inside when shook?
i would take the 97 flywheel/ flexplate and move it too since there is a difference in bell housing and converter likely. just better that way. otherwise it should bolt on as the tcase. dont forgot about swamping the oil pressure switch between the two just in case it was changed from 97-98. the was a wiring change that removed fuel pump control off the switch and entirely to the pcm. as a result the switch design is likely changed. will look a tech data later but other wise so far you are good to go. let me know of any data you need. and if you have done the engine dizzy install before swap it before you put it in so you can get the CAM_RETARD setting dean on the first time. would avoid needing a scanner later.
