Driver Switch problem
MyDenaliDelilah
2010 Yukon Denali
I recently had to replace my driver side mirror. Job was simple as they could make it. I put everything back together and my driver window will no longer roll up. I sent 12v directly to the window motor. Getting it to raise and close. The switch will not lower the window now. I checked the wiring harnesses and everything seems to be good order. No popped etc. I pulled the switch apart and check all the contacts and switch operation. I cleaned them all with contact cleaner anyway. Reassembled the switch. Still nothing. Now I can use it to open all the other windows, move my mirror, unlock and lock doors, and the child safety button works. Someone please help!!
I cannot personally help you with your question; however, other members on this Forum that are much more knowledgeable than me will chime in.
Was the replacement mirror an exact replacement (same year and model)?
Moderator
People's Republic of Colorado
SWAG Maybe blow a fuse?
If you use your external 12v to roll it down, can you roll it UP with the OE wiring by using the switch?
EDIT: I'd be checking the motor wiring connectors for bent pins, and then for voltage using the switch. Test light or VOM.
worleytrev93
