SOLVED. Underneath the driver door "power window master control" (for lack of a better term) are 4 plugs, one of which has a latching mechanism that holds the plug into the switch block. When I removed the door panel to upgrade the door speaker, I noticed that the latching mechanism was broken in two places, probably from someone removing it previously. When I tried to put it back together, it broke into a bunch of pieces. I drove over the local salvage yard and purchased a door harness so I get that latch off of another plug and swap it onto mine. Buying the whole harness was the only option and it was $35 bucks! Interestingly enough, I had re-installed the original door latch and double checked all of the three wiring connections there. When I started plugging in those 4 connectors located under the power window master control, I noticed that the interior lights came on once I latched that plug into place. I have tested it numerous times and everything seems to be working correctly now. So for future reference, all plugs on the door must be connected (correctly) when testing lighting and such... Thanks for all who helped me out with direction here.
