Denali Grill
HAARubicon
Well I figured it out. Pay the dealer $100 and enjoy your new grill.
HAARubicon
I think it looks much better. It actually rides better and has more power since it thinks its a Denali. :waytogo:
Steve1081
The chrome looks great with the red!
garlandyukon
I should be getting my grill in tomorrow and found a dealership in DFW that will install it for $65.
rokdenali
Souther California
What about a fully blacked out grill frame?
Does anyone have a suggestion on the easiest way to get the chrome frame surrounding the grill blacked out?
Pockets
West Ga
Just paint it... I had my grille painted and tail lights tinted for $80.
Piper Pilot
Southern Connecticut
I ordered the Denali grill and will attempt to install. We are in the install Biz for Public Safety equipment so removing the front end plastics should not be too bad. I'll try to take pictures and document what needs to be done.
A quick look reveals inner fender well screws, top side molding screws and probably inner fender screws. Lots of hidden stuff that you can't see unless you remove other panels. This will also allow me access to the Pass side headlamp to change out the bulbs. Looks like you have to remove the airbox (Airfilter) to gain access to the pass side bulbs.
DragStripCourage
Looking forward to seeing install feedback.. Any pics you can take along the way would be great.
Prormk
Alaska
I second that piper pilot. A full write up will help us all immensely.
ajs800
Michigan
It is very easy.... I installed an OEM one last week on our XL SLT. It took just over an hour by myself. The only area that is tough and where you need to be careful are the tabs at each corner of the bumper just under the headlights where it attaches to the fender. once everything is unbolted the tabs still hold the skin on pretty tightly. Unfortunately, I didn't take any pics of install.
I used the putco online instructions to determine what bolts needed to be removed.
http://www.realtruck.com/shared/pdf/manufacturers/2/270519b.pdf
ajs800
Michigan
BTW - A cordless drill for the 7mm and 10mm will save a lot of time vs a ratchet.
WillieFlo
Houston, Tx
Lamin-X film then get HIDs in the stock projectors?
Tint
Gunsmoke
I'm planning on doing the tint for the rear tails / upper brake and the front headlight housings, but want to leave an opening in the front of the actual high/low lens area.....
curbud
