2018 GMCYukon Denali Front Magna Ride shock Replacement
Nyjetfan21
I have a 2018 GMC Yukon Denali. I need to replace my front magna ride shocks. I was wondering if anyone can tell me what are a good replacement for my front shocks. Also a good How to video on how to install them is it something simple enough i can do at home. I was going to purchase them from parts geek. Please let me know the best replacements ty
You are best to go with OEM shocks on the truck, particularly where all 4 wheels are electronically integrated into the suspension system. You can find OEM Magneride replacements on RockAuto.com and GMPartsDirect.com at prices significantly below dealer prices.
Yes, you can perform this replacement by yourself. The only tricky part is compressing the springs to allow you to disassemble the strut and replace the shock itself. You can rent heavy duty spring compressors at a local auto parts store that rents out equipment. Alternatively, you can remove the strut assembly, take it along with the replacement shock to a local trusted auto repair shop, and have them make the swap, using their heavy duty press, and then you can re-install the strut assembly back into the truck yourself. This alternative is much safer for you, much quicker timewise, and probably won't cost you more than $75 for the labor.
N
Nyjetfan21
Can I just buy the whole assembly with the spring and Shock all in one and just un bolt the old and rebolt, the new one in.
N
Nyjetfan21
Also, how much did the shocks run about if I had them installed compared to doing it myself?
N
Nyjetfan21
I also went on rock auto not sure which one to get or which one is the OEM if someone could maybe please post a link I have the Yukon Denali 2018 with the 6.2 L
I do not believe that GM sells the entire assembly, but instead, it sells part by part.
Generally, the strut is under $400, and I would guess that a local repair shop would charge you about $250 in labor to perform the entire job.
To identify the specific strut for your truck, please post a photo of your RPO code sticker, and we can determine the specific strut part number from that information.
Alternately, please post the last 8 characters of your VIN, and @915_Tahoe may be able to provide you with the strut's part number for your truck.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
I have a 2018 GMC Yukon Denali. I need to replace my front magna ride shocks. I was wondering if anyone can tell me what are a good replacement for my front shocks. Also a good How to video on how to install them is it something simple enough i can do at home. I was going to purchase them from parts geek. Please let me know the best replacements las
Last 8 of the vin#
CRN_25
