Dead battery
rchurch5945
Bridge City, TX
I've got a 1996 2 door 2 wd Tahoe. I'm in the process of lowering it 4" and rebuilding the suspension. I have it in my shop up on jackstands. I don't have a lot of extra time, so I've been working on it off and on for the past 4 months. After I finished the rear suspension, I decided to crank it up just for the heck of it. The battery was completely dead. I thought, "no big deal" and disconnected the cables and put the charger on it overnight. The next day I reconnected the cables. JUST AN FYI- when I reconnected the battery the emergency flashers started flashing and it wouldn't even try to start. After researching some, I found out it is the anti-theft. Turn the key to the on position, leave it on for 10 minutes, turn the key off for 20 seconds, and it starts.
So, back to the battery. Started it up, let it run for a while and turned it off. Thought everything was ok. Came back the next day - completely dead again. Disconnected the cables again, recharged it over night, and tested the battery. 12.7 volts. Left it disconnected for a week, tested it again, 12.4 volts. Battery seems to be good. Hooked the cables up, started it, tested it while it was running - 14.4 volts, so the alternator is charging. Next day - dead.
I noticed when I was connecting the positive cable it sparked big time. Not just the little spark when connecting a battery. This tells me I have a short somewhere maybe? Is there something particular about these Tahoes I can check? I'm not looking forward to just tracing out wires and hope I find it.
I drove it daily for about 6 months before putting it in my shop and never had any problem with it. HELP!
wjburken
Eastern Iowa
How old is the battery? Might be worth your time to get it tested. You might have a bad cell.
How long did you let it run for? Imo, letting it idle doesn't give the battery the necessary charge that it needs to maintain it. Driving it is much better to charge it. I know it's on jack stands. Might be better off to leave it on the charger, then to leave it connected to the truck. You have a few constant draws on the battery--clock, pcm etc, even tho they're small, they're still a draw that adds up.
OR VietVet
GMT800 2005 Tahoe Z71
Navy Supporting Member
Willamette Valley
Sounds like a sulfated battery that is old enough and sat long enough that now it will not hold a charge. Replace it, make sure connections are good and tight and clean at both ends of the cables and then deal with anything else that may come up. The battery is the heart of the electrical system. It has to be up to *****.
^^^ THIS!!! ^^^^
If the truck is not going anywhere for a while, you might kick the can down the road a bit and get this:
https://www.amazon.com/BatteryMINDe...teryminder&qid=1584988973&s=automotive&sr=1-7
BG1988
if you going to store it for a long time pull it from the truck and bring it inside
battery maintainer is not required you can store it for a month or two no issue
if it's sitting cold or heat cycles will be bad for it and it will drain out.
14.4v is a little low for the truck it should be at 14.8-15v when charging check the terminals and clean them it could be dirty on the connectors (i took my terminals apart they were pretty dirty causing things not to operate correctly my voltage was too low only 14.3volts on a cold start and it was all over the place) now it's at 14.8 14.9volts on a cold start and you bet i bought new ones for nothing(but keep them as a spare)
i don't know if you have side posts or not but you can pick up a new AGM battery for 150$ at walmart
It's not holding a charge Brent. Something is wrong with it. There's a good chance that the tender will revive the battery.
BG1988
ahh better to replace it then try to "fix it"...
unless you able to take it apart and rebuild it, he should check the acid levels if it's not sealed( gotta use safety equipment ) some auto store do have battery fluid.
i tried fixing mine it only bought me a few more months...and stalled in the middle of traffic because of it .. I know for the future it's never worth the risk in my area since our speed limits are 40-60 mph.. luckly it stall on a left green arrow and not on a Yield.. i think the momentary drop to 9volts was a internal short as it fired right up then i went to Walmart and bought a new one
NoReverseYukon
NE Wisconsin
It could be stratified. You didn't mention if it was maintenance-free or not.
If so, or if you can keep it from leaking on you, it might be worth a shot at mixing up the electrolyte by shaking/tipping the battery back and forth. Mine came back to life after I did that. Just be careful and cover any caps with a rag to protect yourself.
R
rchurch5945
Bridge City, TX
I appreciate all the quick responses. The battery is maintenance free and was purchased in 2018 by the previous owner. It is very small so I assume they bought the smallest, cheapest they could find. I feel it is still good since I disconnected it and it held a charge for a full week.
Once I finish the suspension and am ready to drive it regularly, I think I'll go ahead and replace the battery with a decent one and attack this issue at that time.
I cleaned the terminals (which are side posts) and made sure they are fully connected. I think I'll clean the other end of the cables to make sure they are clean and well connected and check that the cables themselves are in good shape.
I did some more research and found an older post here where someone suggested using a multimeter to test the milliamps draw through the negative cable. If it's higher than around 50 mA then there is something drawing power other than the usual things (clock, etc). You then begin taking fuses out one at a time and testing and when the excess draw goes down then that is the circuit that has the problem. You then trace each part of that circuit out until you find the problem. That makes sense to me and is a whole lot less work than tracing every electrical system out and hoping you find it.
But hopefully, it is something as simple as the battery!
Thanks everyone and I'll post some pics. I love the Tahoe and got big plans for it!
R
rchurch5945
Bridge City, TX
R
rchurch5945
Bridge City, TX
R
rchurch5945
Bridge City, TX
OR VietVet
Willamette Valley
Spend the money and get an AGM battery in the neighborhood of $150. Good thoughts on the cables maintenance. The multimeter test is spot on. I used to run shops and the 50ma threshold used to be the norm but with the newer vehicles and more computers involved with so many vehicle systems that threshold is higher now. Someone here will chime in with that new normal reading threshold. When you do test, the place to start is the alternator. Unplug it and see what happens on any draw reading. The diode tray in there is a known culprit and easy to test for when you start testing. It likely is the battery but does not hurt to test further and you learn as you do it as well.
OR VietVet
Willamette Valley
Something also tells me that you are experiencing the slow post posting time and you hit Post Reply a few times. Sometimes it is quick here and sometimes very slow to post a reply.
R
rchurch5945
Bridge City, TX
Sorry for the multiple replies. I can't tell if it's the site or my computer. I'm definitely replacing the battery. What is an AGM battery. Assuming it is a brand but I'm not familiar with it. I do like the EverStart Maxx from Walmart but we have a small Walmart here and the selection is great.
The post I found on the testing seem to indicate the 50 mA was good for a 96 and it was newer models that had the higher threshold. Anyone have any thoughts on that?
I'm also thinking the alternator as you said so I will test it first.
OR VietVet
Willamette Valley
Yea, the older models 50ma threshold should be good. I was referring to the newer rigs because I did not want to go back and scroll to find your year of rig.
"The sulfuric acid is absorbed by a very fine fiberglass mat, making the battery spill-proof. ... The battery stands up well to low temperatures and has a low self-discharge. The leading advantages of AGM are a charge that is up to five times faster than the flooded version, and the ability to deep cycle."
"AGM or Absorbent Glass Mat is an advanced lead-acid battery that provides superior power to support the higher electrical demands of today's vehicles and start-stop applications. AGM batteries are extremely resistant to vibration, are totally sealed, nonspillable and maintenance-free."
This says it better than I can.
Drewphil
