skpyle
- Joined
- May 15, 2021
- Posts
- 395
- Reaction score
- 1,025
Hello All!
My 2013 Escalade ESV has the power running boards. I very much like them, and want to keep them working properly for a long time. Neither the owner's manual nor the service manual have any useful information (that I could find) on the care and feeding of these beasts.
Searching this forum, I have gathered that the most important tip is to keep them lubricated. OK, specifically what should I lubricate? I would assume the hinges. I have heard mention of lubricating the motors as well.
What is the preferred flavor of lube? WD-40? Silicone spray? Unicorn's blood...?
As well, I have a procedural question: is there a way to lock the running boards in the extended position? I want to have the running boards extended when I wash the Escalade. I have found nothing in the owner's or service manual regarding this. Owner's manual shows a push button under the HVAC controls that locks the running boards out and prevents them from extending. It does NOT prevent them from retracting.
I found a procedure on the internet, and have used it a couple of times. However, I am not 100% comfortable with it: open a door, extend the running board, set my foot firmly on the running board, close the door. The running board will sense it is obstructed and not retract. Open and close a door again to retract the running board. It seems to work OK, but I can't shake the feeling I am damaging something. Like a slip coupling...
Thanks for your time and comments!
