trailblazer
- Joined
- Jan 22, 2019
- Posts
- 291
- Reaction score
- 404
Anyone do this using a bead breaker tool like the "Little Buddy"?
To answer your question, yes. But, places like Discount Tire will usually replace the sensor & program (if you already have the replacement) for like $5-10.
Thanks for this answer, I know there are two different MHz sensors, how can you tell which you have? I need to order some, as at least one is dead. I figure I'll order 4.
rpo code in your glove box or build sheet will tell you for sureThanks for this answer, I know there are two different MHz sensors, how can you tell which you have? I need to order some, as at least one is dead. I figure I'll order 4.
xl7=315mhz
xl8=433mhz
Yeah I have to check the glovebox too, at the top of my build sheet it says: " *IVH is not the definitive source of GM Vehicle RPO information..."That's funny... I don't have either code... at least not on the printout I got from GM. I will have to double check my glove box.
Thank yourpo code in your glove box or build sheet will tell you for sure
xl7=315mhz
xl8=433mhz
That’s the way to do it imo (replace all 4). Im the same way with lights on my vehicles. If one headlight or taillight goes out, I replace both sides.Thanks for this answer, I know there are two different MHz sensors, how can you tell which you have? I need to order some, as at least one is dead. I figure I'll order 4.
ahh... I don't have either in my glovebox... hrmm.rpo code in your glove box or build sheet will tell you for sure
xl7=315mhz
xl8=433mhz
hmm, on Monday you can go to the gm website, go to chat, select (question about a vehicle I already own), give the chat person your vin and they can email you the build sheet for your vehicle, they will need to confirm that you are the owner is all, it's freeahh... I don't have either in my glovebox... hrmm.
I wasn't clear I already have the build sheet, they sent it last week. doesn't mention it at all. Nor does the RPO codes in the glovebox...hmm, on Monday you can go to the gm website, go to chat, select (question about a vehicle I already own), give the chat person your vin and they can email you the build sheet for your vehicle, they will need to confirm that you are the owner is all, it's free
you must be missing it somehow they are alphabetically listed, see my photo post on the first pageI wasn't clear I already have the build sheet, they sent it last week. doesn't mention it at all. Nor does the RPO codes in the glovebox...
if nothing else call your local dealer's parts department and give them the last 8 of your vin or send it to @915_Tahoe
